Blank Datagrid
1458
06-03-2011 01:16 PM
AgatinoLa_Rosa
I have a simple query on a web service and the result should populate a datagrid. However I get a blank datagrid and I may have done something wrong. Any help?
At design time:
<sdk:DataGrid  Name="grdCity" AutoGenerateColumns="False" HorizontalAlignment="Left" HeadersVisibility="All" CanUserResizeColumns="False" CanUserReorderColumns="False">
<sdk:DataGrid.Columns>
<sdk:DataGridTextColumn Header="City" Width="400" Binding="{Binding Attributes[NAME]}" />
<sdk:DataGridTextColumn Header="2010 Population" Width="220" Binding="{Binding Attributes[Pop_2010]}"  />
</sdk:DataGrid.Columns>
</sdk:DataGrid>
At runtime:
            InitializeComponent();
            QueryTask qryCity = new QueryTask("http://myserver/rest/services/.../MapServer/0");
            qryCity.ExecuteCompleted += qryCity_ExecuteCompleted;
            qryCity.Failed += qryCity_Failed;
            Query allCitiesQuery = new Query();
            allCitiesQuery.OutFields.AddRange(new string[] { "NAME", "Pop_2010" });
            allCitiesQuery.ReturnGeometry = false;
            allCitiesQuery.Where = "State='myState'";
            qryCity.ExecuteAsync(allCitiesQuery);
void qryCity_ExecuteCompleted(object sender, QueryEventArgs args)
            FeatureSet fsetCity = args.FeatureSet;
            myDatagrid.ItemsSource = args.FeatureSet.Features;
DominiqueBroux
Esri Frequent Contributor
At first glance your code looks good.
The only strange thing is that your datagrid is called 'grdCity' in XAML and 'myDataGrid' in C#.   Is it supposed to be the same thing?
AgatinoLa_Rosa
I found that I had the datagrid inside a scrollviewer object that caused the problem. Now is working. thanks. the mydatagrid.itemssource was my mistyping on the post
One more question. Is there any example I can see so I can pass an object with my query features to another page of my SL navigation application? i.e. I have the features queried in PageA and the DataGrid in PageB. I have used the DataContext property on PageA however PageB receives an empty object. Thanks
DominiqueBroux
If your pageB contains only the datagrid, you can use the DataContext of the PageB to store the list of graphics.
In your C# code : set the datacontext of your pageB:
    pageB.DataContext = = args.FeatureSet.Features;
In XAML, bind the itemssource of your datagrid to the datacontext itself, i.e. <controls:DataGrid ItemsSource='{Binding}' ....
AgatinoLa_Rosa
It is not working. Perhaps I am not sure how to initialize PageB into PageA.
in the declaration section of my PageA I have:
private PageB _mypageB = new PageB();
in my "qryCity_ExecuteCompleted" (in PageA) I have:
_mypageB.DataContext = args.FeatureSet;
In my PageB I have:
if (this.DataContext == null) {return;};
and it stops there, so PageB.DataContext is null.
Is this correct?
