Binding to Envelope parameters on ZoomToAction
1745
07-29-2010 11:41 AM
MikeTischler
I'm creating a series of bookmarks with the names and extents of the bookmarks being bound to an external XML file.  I've added the XML as a date source in Expression Blend.  I've got a listbox like below:
<ListBox x:Name="Bookmarklistbox" ItemTemplate="{StaticResource bookmarkTemplate}" ItemsSource="{Binding categoryCollection}" >
</ListBox>
I've put the ItemTemplate in the UserControl resources and it looks like this:
<DataTemplate x:Key="bookmarkTemplate">
<StackPanel>
<TextBlock Text="{Binding name}"/>
<Button Name="bookmarkbutton" />
<i:Interaction.Triggers>
<i:EventTrigger EventName="Click">
<esriBehaviors:ZoomToAction TargetName="Map">
<esriBehaviors:ZoomToAction.Geometry>
<esriGeometry:Envelope
XMin="{Binding XMin}" YMin="{Binding YMin}" XMax="{Binding XMax}" YMax="{Binding YMax}"/>
</esriBehaviors:ZoomToAction.Geometry>
</esriBehaviors:ZoomToAction>
</i:EventTrigger>
</i:Interaction.Triggers>
Now, The button content shows up as it should with the correct bookmark name.  However, I can't get the Envelope parameters to bind without an error.  The error I'm receiving is "Object of System.Windows.Data.Binding cannot be converted to System.Double"
If I switch the button content to {Binding XMin}, the content changes to a coordinate...so I know I'm in the right neighborhood.  But, I can't seem to figure out how to bind this correctly.
Any thoughts?
JenniferNery
Unfortunately these Envelope properties (XMin, YMin, XMax, YMax) are not dependency properties that's why you cannot bind to them.
Jennifer
MikeTischler
Ah - I see.  Thanks for filling me in.
I found a workaround (if anyone is interested).  First I changed my XML.  Where there were 4 properties(Xmin, Ymin,Xmax,Ymax) for each entry before, there is a single comma-delimited string now.  I can bind that to the button.tag in the data template and parse that string in code behind on the button's click event handler.  Then I create a new envelope, and pass the parsed string parts to the bounding box coordinates of the new envelope.  Finally, I call Map.ZoomTo(mynewenv) and it works.
mike
MichaelLibio
Jennifer
Is there a way to extend the Envelope class to include properties (like a wrapper) that are dependency properties?
public static readonly DependencyProperty BindableXMaxProperty =
    DependencyProperty.Register(
    "BindableXMax", typeof(Double),
public double BindableXMax
    get
        return (Double)GetValue(BindableXMax);
    set
        this.XMax = value;
        SetValue(BindableXMaxProperty, value);
Let me know what you think.
--Michael
