Binding search result from FindTask to ListBox using DataTemplate SL4
6142
13
03-07-2011 10:06 AM
MariaFernandez
Hi, I am trying to bind the FindTask result to a listbox with ItemTemplate defined as a StaticResource (DataTemplate).
I got error:
Unable to cast object of type 'System.Windows.Data.Binding' to type 'System.Collections.IEnumerable'
Thanks!!
DominiqueBroux
Esri Frequent Contributor
How looks your binding?
MariaFernandez
I have this control in the mainpage.xaml
<ListBox x:Name="SearchListBox" Background="White"
                                         ItemsSource="{Binding}"
                                         ItemTemplate="{StaticResource FeatureDataTemplate}"
                                         VerticalAlignment="Top">
                <ListBox.ItemsPanel>
                    <ItemsPanelTemplate>
                        <StackPanel Orientation="Horizontal"  />
                    </ItemsPanelTemplate>
                </ListBox.ItemsPanel>
            </ListBox>
The resource defined in the same page  is
<ItemsPanelTemplate x:Key="ItemsPanelTemplate1">
            <StackPanel Orientation="Horizontal"/>
I have a class Feature.vb
and a DataTemplate
<DataTemplate x:Key="FeatureDataTemplate">
        <Grid Width="auto">
            <Grid.RowDefinitions>
                <RowDefinition Height="Auto"/>
                <RowDefinition Height="85"/>
                <RowDefinition/>
            </Grid.RowDefinitions>
            <Grid.ColumnDefinitions>
                <ColumnDefinition Width="Auto"/>
            </Grid.ColumnDefinitions>
           <Border BorderThickness="3" BorderBrush="Green" Grid.RowSpan="2" Grid.Column="0" >
                <Image Source="{Binding PhotoUri}" Stretch="Fill"   />
            </Border>
            <dataInput:Label Content="{Binding FeatureLayerName}" Grid.Row="0" Grid.Column="1"/>
            <dataInput:Label Content="{Binding FeatureLayerItemCount}" Grid.Row="1" Grid.Column="1"/>
            <ListBox  Padding="2" Grid.Row="2" Grid.Column="0" Grid.ColumnSpan="2"
                     ItemsSource ="{Binding Path=FeatureItems}"
                     ItemTemplate="{StaticResource FeatureItemDataTemplate}"
        </Grid>
    </DataTemplate>
    <DataTemplate x:Key="FeatureItemDataTemplate">
        <Grid >
                <ColumnDefinition Width="50"/>
                <ColumnDefinition Width="100"/>
            <Grid.RowDefinitions >
                <RowDefinition ></RowDefinition>
            <sdk:Label x:Name="labelName" Content="Name:" Grid.Column="0" Grid.Row="0"/>
            <dataInput:Label Content="{Binding Path=Name}" Grid.Row="0" Grid.Column="1"/>
            <sdk:Label x:Name="labelOwner" Content="Owner:" Grid.Column="0" Grid.Row="1"/>
            <dataInput:Label Content="{Binding Path=Owner}" Grid.Row="1" Grid.Column="1"/>
        </Grid>
    </DataTemplate>
In the executebutton click handling the FindTask I have:
SearchListBox.SetBinding(ListBox.ItemsSourceProperty, resultFeaturesBinding)
I am missing a way to assign the resultFeaturesBindeing to the getData in the Feature class (I don't know how to doit.)
Something like:
Dim features = Feature.GetData(resultFeaturesBinding)
   Me.DataContext = features
Thanks for your help!!
DominiqueBroux
At this time, I don't understand why you have 2 levels of listbox : one in your SearchListBox and one in your FeatureDataTemplate.
Let's focus on the first level. The goal is to initialize the 'ItemsSource' of your SearchListBox with an Enumeration of something.
It turns out out that the 'FindResults' returned by the 'FindTask' is a List of 'FindResult', so it's a good candidate as an ItemsSource.
To use it, there are 2 ways:
- Hook up an handler to the ExecuteCompleted event and, in the handler, initialize the DataContext of your control with e.FindResults (that's probably the easier way).
or - Set a binding by code to the LastResult property of the FindTask. The sample is working this way by this code:
           Binding resultFeaturesBinding = new Binding("LastResult");
            resultFeaturesBinding.Source = findTask;
            FindDetailsDataGrid.SetBinding(DataGrid.ItemsSourceProperty, resultFeaturesBinding);
.Then in your FeatureDataTemplate you can use properties of a 'FindResult' (i.e. LayerName, LayerId, Feature, Value, ...)
So your XAML code
</Border>
should rather be (since I don't see where FeatureLayerName, FeatreLayerItemCount and PhotoUri are coming from) :
<Image Source="{Binding Feature.Attributes[PhotoUri]}" Stretch="Fill" />
</Border>
<dataInput:Label Content="{Binding LayerName}" Grid.Row="0" Grid.Column="1"/>
<dataInput:Label Content="{Binding LayerId}" Grid.Row="1" Grid.Column="1"/>
<dataInput:Label Content="{Binding Value}" Grid.Row="1" Grid.Column="1"/>
Hope this help.
MariaFernandez
Thanks for your help!!!
I used your first suggestion and is working!!!!:
I passed the e.FindREsults to the getData function in the feature class and the double list is populated.
I used:
Public Shared Function GetData(ByVal data As Object) As IEnumerable(Of Feature)
        Dim list As New List(Of Feature)
        'list.Add(New Feature With {._featureLayerName = "FeatureLayerName1", ._featureLayerItemCount = "5 feature(s) found"})
        'list(0)._featureItems.Add(New FeatureItem With {.Name = "1FeatureItemName1", .Owner = "FeatureItemOwner"})
        'list(0)._featureItems.Add(New FeatureItem With {.Name = "2FeatureItemName2", .Owner = "FeatureItemOwner"})
        'list(0)._featureItems.Add(New FeatureItem With {.Name = "3FeatureItemName3", .Owner = "FeatureItemOwner"})
        'list(0)._featureItems.Add(New FeatureItem With {.Name = "4FeatureItemName4", .Owner = "FeatureItemOwner"})
        'list(0)._featureItems.Add(New FeatureItem With {.Name = "5FeatureItemName5", .Owner = "FeatureItemOwner"})
        Dim i As Integer = -1
        Dim CurrentLayer As String = ""
        For Each elem As ESRI.ArcGIS.Client.Tasks.FindResult In data
            If String.Compare(CurrentLayer, elem.LayerName, System.StringComparison.OrdinalIgnoreCase) <> 0 Then
                list.Add(New Feature With {._featureLayerName = elem.LayerName, ._featureLayerItemCount = "5 feature(s) found"})
                CurrentLayer = elem.LayerName
                i = i + 1
            End If
            list(i)._featureItems.Add(New FeatureItem With {.Name = elem.DisplayFieldName, .Owner = elem.Value})
Return list
    End Function
Now I got the list almost as I like it.
I need specifics fields from the layer instead what I am getting is the fields that have the information searched.
Also I need functionalities when mouse over the list item to displaythe feaures it in the map. How I could do that? I had this working using the grid.
THanks a lot for your help!!!!
Maria
MariaFernandez
Additionally to this,
How we can search only in the visible layers?
Instead of
findParameters.LayerIds.AddRange(New Integer() {0, 1, 2, 3})
search in the visible only.
Thanks!!!!
DominiqueBroux
The FindResult object contains a feature object with all its attributes. So you can extend your FeatureItem to store other attributes:
     .OtherAttribute = .elem.Feature.Attributes["AttributeName"]
or even to store the whole Feature:
.Feature= .elem.Feature
Also I need functionalities when mouse over the list item to display the feaures it in the map. How I could do that?
That will be easier if you store the Feature in your FeatureItem. So (as in the sample) from the SelectedItem, you can retrieve the Feature and show it in a graphics layer.
Asgharkhan
@Dominique i want this binding behind C#
How to?
<slData:DataGridTextColumn Binding="{Binding Attributes[FID]}" Header="النتائج" />
DominiqueBroux
This thread Defining Results Datagrid In Code behind should help.
MariaFernandez
Thanks a lot!!
Using the Feature.Attributes I got the info I needed:
list(i)._featureItems.Add(New FeatureItem With {.Name = elem.Feature.Attributes("NAME").ToString, .Owner = elem.Feature.Attributes("OWNER").ToString})
            list(i)._featureLayerItemCount = ItemLayerCounter.ToString & " feature(s) found"
Thanks!!
I also need the legend dymbol for the layer. The image I have in the feature class is to store the legend symbol for the layer. How we can access that information?
Thank you very much for all your help!!!
