Binding Query Result To FeatureDataGrid
5674
12
07-26-2011 01:24 AM
ManojrajTeli
I am trying to bind the query result returned from by query to the FeatureDataGrid but instead of attributes the geometry of the result is getting bound to Feature datagrid.Please suggest the code to bind attributes to FeatureDataGrid.Thank you in advance.
JenniferNery
FeatureDataGrid will display fields that are in your graphic.Attributes. If your FeatureDataGrid.GraphicsLayer contain the results of your query and you have specified query.OutFields, these should be the same fields contained in the FeatureDataGrid.
Your FeatureDataGrid.Map and GraphicsLayer need to be set, similar to this:
        <esri:FeatureDataGrid Grid.Row="2" x:Name="MyDataGrid"
    Map="{Binding ElementName=MyMap}"
    GraphicsLayer="{Binding ElementName=MyMap, Path=Layers.[MyGraphicsLayerID]}" />
ManojrajTeli
Oh thank you but this is during initialization that i have done already i want the part QueryTask_ExecutionCompleted event.
This is the Piece of Code what i have done.
Void queryTask_ExecuteCompleted(Object sender,ESRI.ArcGIS.Client.Task.QueryEventArgs e)
          FeatureSet featureset=e.FeatureSet;
          if(featureset != null && featureSET.Feature.Count>0)
                   MyDataGrid.ItemsSource = featureSet.Features;//Here the attributed I have to bind
        //Geometry is getting binded
Suggest some way to bind attribute from feature set to FeatureDataGrid
DominiqueBroux
Esri Frequent Contributor
The ItemsSource of your FeatureDataGrid must reference the graphics instance that are inside the layer.
So instead of setting the ItemsSource directly to the result of the query, you have to project the query result in order to get graphics instances in the feature layer (by using the objectID).
There is a sample in this thread : http://forums.arcgis.com/threads/18708-Problem-selecting-features-from-a-Feature-Layer
ManojrajTeli
Can please elaborate ...I am new at this and i tried those codes and not working and i want to show all the fields in feature datagrid depending on records selected by query and result returned...Its urgent.Thanks in advance.
JenniferNery
Actually, you should not be setting FeatureDataGrid.ItemsSource property.
As long as FeatureDataGrid.Map and GraphicsLayer are set. All you have to do in the Query.ExecuteCompleted event handler is add the results to your GraphicsLayer.Graphics.
ManojrajTeli
I am directlly fetching the Featuredatagrid from query on featureservice and i can see geometry,map tip etc columns but i don't know how to bind only features columns from query result.If you have code then please share. thanks its urgent.Thank you in advance.
JenniferNery
Code is in post#2 This is all the Binding you will need for FeatureDataGrid.
This SDK sample shows how you can add results as graphic to your GraphicsLayer (see code-behind QueryTask_ExecuteCompleted):
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SpatialQuery
EzequiasRodrigues_da_Rocha
Have someone solve the problem of showing the attribute table yet? Actually I do not have fixed attribute columns. I just want to display the attribute table of one layer with all values as I can see in ArcMap, but in my case I want to display using Silverlight.
Here is the code that retrieves the FeatureSelection:
QueryTask queryTask = new QueryTask(url);
queryTask.ExecuteCompleted += new EventHandler<QueryEventArgs>(queryTask_ExecuteCompleted);
Query query = new Query();
query.ReturnGeometry = true;
// Use textbox text as query condition.
query.Where = "1=1";
query.OutFields.Add("*");
queryTask.ExecuteAsync(query);
And the population I was trying to make:
void queryTask_ExecuteCompleted(object sender, QueryEventArgs e)
attribWidget.featureDataGrid1.Map = this.MapControl;
attribWidget.featureDataGrid1.ItemsSource = e.FeatureSet.Features;
But I have no success neither with DataGrid nor FeatureDataGrid
ps: I don't want to make any previous selection on the map, so I don't need a graphic layer. I just want to display attributes on FeatureDataGrid
Is it possible to bind without making a spatial selection? I just want to bind the attribute table of my layer.
Any suggestion will be welcomed.
Regards
Ezequias Rocha
