Bar chart symbol renderer
4023
7
11-23-2010 06:51 AM
stefanschlaefli
Hi
Is it possible to symbolize a data attribute with a bar- or a pie chart symbol? Is there a renderer available?
Thank you
Stefan
AliMirzabeigi
Please take a look at the following code gallery sample to get the whole idea:
http://resources.esri.com/arcgisserver/apis/silverlight/index.cfm?fa=codeGalleryDetails&scriptID=165...
RodolfoMoreno2
Hi Ali Mirzabeigi, I was reserching about chart rendering in esri resource center and it's seems that there is no exist this type of rendering yet. Is this correct?
(P.S. the link that you suggest to link just to the home page of the resource center)
Regards,
DominiqueBroux
Esri Frequent Contributor
The piechart sample is now in the arcgis.com application gallery :
http://www.arcgis.com/home/item.html?id=b135d66549364786b381e85451742d56
GencSalja
Hi to all i was reading the thread and i have download the sampel but it is only for polygon feature  i have a point feature and it doesn't work
DominiqueBroux
There are two parts in the sample:
  1) showing how to display a chart inside a maptip : this part should not be impacted by the geometry type
  2) using a chart symbol to display the states : can be tweaked to work with point features. It even simpler with point features since you don't need to create new graphics, you can symbolize your point features directly.
What kind of issue do you get?
GencSalja
I got it to work thank you ,
ArghaBera
Hi ,
I have simillar kind of requirement to draw piechart as a graphic sysmbol.Can any one please help on this.
Thanks in advance.
