BackgroundWorker and Graphics
1038
08-19-2012 07:21 PM
LanceCrumbliss
Hello,
To keep the map and the progress bar responsive while generating a couple hundred point graphics in code-behind with a handful of calculated attributes, I'm trying to do it in a background worker thread using the backgroundworker class.  However, even this single line
Dim g As New Graphic
as the first and only line in the RunWorkerAsync handler, a cross thread error is generated.
I use the backgroundworker class in other ESRI silverlight projects and it's really handy.  However, this is the first time trying to generate graphics.  Is this just not possible?
Lance
DominiqueBroux
Esri Frequent Contributor
As a graphic contains an UI element, it needs to be created in the UI thread.
If you have lot of calculated attributes, you can do it in a background thread but you need to store the results in an intermediate structure. Then you need to come back to the UI thread to create the graphics.
DominiqueBroux
LanceCrumbliss
Thanks D.  in hindsight that should have been obvious.  and thanks for the idea.
Lance
