ArcGISDynamicMapServiceLayer.FullExtent is Null
2485
6
11-04-2012 11:54 AM
AshakaThakore
i am trying to add a dynamic map service layer, and zoom to that layer, but the full-extent of the layer it is always null...
                ArcGISDynamicMapServiceLayer mylayer = new ArcGISDynamicMapServiceLayer();
                mylayer.DisableClientCaching = true;//recommended
                mylayer.Url = DynamicUrl ;
                mylayer.ID = "CURRENTLAYER";
                int totlayers = this.MyMap1.Layers.Count;
                this.MyMap1.Layers.Insert(totlayers, mylayer);
                Envelope anenv = mylayer.FullExtent;
                 MyMap1.ZoomTo(anenv);
//anenv is always null
how do i handle that?
thanks a lot
deleted-user-ATjHIWsdQYmT
You have to initialize your DynamicMapServiceLayer in order to be able to get it's full extent.  There is an Initialize() method to call.  Then you have to add an event handler to handle the initialized event.  In that handler, you can zoom the map to the layer's extent.
AshakaThakore
Do I have to initialize after inserting the layer to the map or before ?
mylayer.Initialized += new EventHandler<EventArgs>(mylayer_Initialized);
mylayer.Initialize() ;
Please help.. thanks a lot
I'd probably do it after you insert it into your map.  Are you trying to insert the layer at a specific place in your layer order?  Otherwise you can just use MyMap.Add(mylayer);
AshakaThakore
Yes, i am trying to insert at particular location
here on this link i found that i should insert after initialize is done
http://forums.arcgis.com/threads/59382-Layer-not-initialized?highlight=arcgis+layer+initialize%28%29
So It did work...
now the problem is i want to zoom to that layer after its initialized and my my map's SRID is 102100
And my layer's projection/SRID is different and if i do - mymap.zoomto(mylayer.fullextent) it zooms to wrong place bcos SRID are different
pl help
how should i project that fullextent to srid 102100 or how should i handle this problem
thanks a lot
You can use a GeometryService to project your envelope from your layer's spatial reference to 102100.  Here's the API documentation with example:
http://resources.arcgis.com/en/help/silverlight-api/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tas...
Note the input has to be a graphic so you can just create a new graphic using the extent of your envelope.  You'll raise a "ProjectCompleted" event.  From there you can take the result and use that to zoom to your layer extent.  That'll work.
DominiqueBroux
Esri Frequent Contributor
You can find a sample of what Andrew mentioned here.
You have to wire up the 'ZoomToFullExtent' handler to the  'Initialized' layer event.
The handler projects the fullextent to the map spatial reference coordinates (using a geometry service if needed).
