ArcGis API for Silverlight 3.1 Draw object snapping issues
1169
09-18-2013 12:06 PM
LeonardoCarmo
I'm using the draw object to create polylines, and when I updated the API  from 3.0 to 3.1, the snapping function stoped working properly. On the 3.0 API the snapping could be used from the moment the draw gets enabled, but on the 3.1 the snapping only works from the second vertex.
CiprianLazar
I'm having the same problem. Did you find any solution to this problem?
ZilvinasKiela
It's a bug. It has changed from API version 3.1.
ESRI, we really need a fix.
