Adding wms layer from geoserver
3484
08-09-2011 05:11 AM
devrim_barisacar
I have some questions regarding to adding a  wms layer from geoserver to a silverlight based map.
First problem is, I cannot delete the esri basemap(ArcGISTiledMapServiceLayer, please see below). If I do that , my wms layer also disappears.  You can see my XAML page below;
[INDENT]<UserControl x:Class="SilverlightApplication5.MainPage"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:esri="http://schemas.esri.com/arcgis/client/2009" >
    <Grid x:Name="LayoutRoot">
        <esri:Map WrapAround="True" >
            <esri:WmsLayer  ID="WMS Layer" Layers="nurc:Img_Sample" Url="http://localhost:8080/geoserver/wms" Opacity="1" SupportedSpatialReferenceIDs="3857"  SkipGetCapabilities="True" Version="1.3" />
            <esri:ArcGISTiledMapServiceLayer Url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" Opacity="0.7"  />
        </esri:Map>
    </Grid>
</UserControl>[/INDENT]
In this way I can see my wms layer on map, but if I delete the ArcGISTiledMapServiceLayer  , then my geoserver wms layer also disappears.
Do you have any recommendations?
PS I am using win7 ult. with visual studio 2010, esri silverlight api 2.2 and geoserver 2.1.1.
best regards
baris
DorothyMortenson
Have you tried to bring your WMS into ArcMap as the first layer, then add the esri layer second?  This may give you some idea of what is going on about map extent/projections, etc.
devrim_barisacar
Yes, in fact my config file is in this config already, i have tried both configs.
devrim_barisacar
I have solved the problem using a clientaccesspolicy.xml in geoserver jetty installation. I did not think of this may be the problem since I could see the layer when using it with a basemap...
ArneDahlman
Maybe the map gets the wrong spatialreference.
The first (the undermost) layer added to the map determines what spatialreference to be used.
Try to explicitly set the WKID in codebehind.
For example, in YourMap_Progress
set
YourMap.SpatialReference.WKID = <your wkid>
