Adding thematic map usercontrol in existing application
1546
5
05-05-2014 12:30 AM
saurabhgupta2
Hello Everyone
I am new to silverlight development . I am trying to add new functionalists to the default template. I tried using the sample code
https://developers.arcgis.com/silverlight/sample-code/start.htm#DynamicLayerThematic
so as to create thematic map of the dynamic layer of my map service. Can anyone illustrate the step by step way out to add usercontrol or widgets to the exiting silverlight app??.
Thanks and regards
Saurabh
AhmedEl-Sisi
Hi Saurabh,
Can you post the link of your template so I can know how the widgets is implemented?
saurabhgupta2
Hello
I am using default template of silverlight ( which are used as starting point of development). My development environment is Api 3.2 and VS 2013 . My question is for any general template.
I have no idea how to implement these for dynamic map layer.
Please help me in this.
Thanks in advance
Regards
Saurabh
AhmedEl-Sisi
It will be a good start if you use one of these templates made by esri
https://github.com/Esri/arcgis-templates-silverlight
saurabhgupta2
Hello
Thanks for showing a path . This helped me to get started ( by seeing how ESRI guys applied spatial query tool into there application). But i am looking for reusable sort of usercontrol which once created can be used in multiple projects .
Please help me in this .
Regards
Saurabh
AhmedEl-Sisi
Thematic map sample just depends on a feature layer so you can make a user control in a separate class library (may contains all your reusable controls) and on Feature Layer initialized event pass the feature layer to your control and this should work fine.
Check attached sample (API 3.1 + SL5).
Regards,
Ahmed
