Adding Multiple Point's of Coordinate
3648
10
12-07-2011 04:31 AM
MuhammadWaqar_ul_islam
i m using http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Project sample to plot x,y values
i have add a text file that contain x,y value and plot a last point[x,y] from an array values
My problem is how to add multiple point value from an array not a single value
when i run this code
double ax = 0 ; double ay = 0;
          MapPoint inputMapPoint = new MapPoint(ay, ax, new SpatialReference(4326));
          while (i <= count)
              double.TryParse(test[i, 0], out ax);
              double.TryParse(test[i, 1], out ay);
              inputMapPoint.X = ay;
              inputMapPoint.Y = ax;
              geometryService.ProjectAsync(new List<Graphic>() { new Graphic() { Geometry = inputMapPoint } }, MyMap.SpatialReference, inputMapPoint);
              i++;
its gives this error "Task does not support concurrent I/O operations. Cancel the pending request or wait for it to complete."
DominiqueBroux
Esri Frequent Contributor
The problem is that you execute your task in the loop --> multiple times : that's not supported.
Instead, you should build your graphics list in the loop and execute the task once after the loop.
Something like:
IEnumerable<Graphic> graphics = new List<Graphic>();
while (i <= count)
graphics.Add(new MapPoint(ay, ax, new SpatialReference(4326));
i++;
geometryService.ProjectAsync(graphics, MyMap.SpatialReference, null);
CHRISTOSCHARMATZIS
Something like:
while (i <= count)
i++;
but the IEnumerable does not contain .Add method...?
What can we do then...?
DominiqueBroux
Sorry.
IList<Graphic> graphics = new List<Graphic>();
still getting error on this
graphics.Add(new MapPoint(ay, ax, new SpatialReference(4326)));
Error2:Argument 1: cannot convert from 'ESRI.ArcGIS.Client.Geometry.MapPoint' to 'ESRI.ArcGIS.Client.Graphic'
Error1: The best overloaded method match for 'System.Collections.Generic.ICollection<ESRI.ArcGIS.Client.Graphic>.Add(ESRI.ArcGIS.Client.Graphic)' has some invalid arguments
what next to do
CHRISTOSCHARMATZIS
Sorry.
I try to change it from List to IList but I still have the same error..
I have tried the IEnumerable solution...but I get the same error as....Waqar82_geo.
As thier any other way to plot multiple point
i m stuck here
special help is appreciated
i haved another way but still only single point is ploted on the map
private void mapWells_Loaded(object sender, RoutedEventArgs e)
            GraphicsLayer wellsLayer = mapWells.Layers["WellsLayer"] as GraphicsLayer;
             // wellsLayer = mapWells.Layers["WellsLayer"] as GraphicsLayer;
   if (wellsLayer == null)
                wellsLayer = new GraphicsLayer()
                    ID = "wellsLayer"
                mapWells.Layers.Add(wellsLayer);
                Graphic marker = new Graphic();
                marker.Symbol = new SimpleMarkerSymbol();
                wellsLayer.Graphics.Add(marker);
            double[] x = new double[] { 305737.67, 305937.67, 305837.67, 305637.67 };
            double[] y = new double[] { 2740242.96, 2740252.96, 2742232.96, 2739232.96 };
            //for (int External = 0; External < 1; External++)
            //  for (int Internal = 0; Internal < 1; Internal++)
            MapPoint[] location = new MapPoint[1];
            for (int i = 0; i < 1; i++)
                location = new MapPoint(x, y, new SpatialReference(4326));
                wellsLayer.Graphics[0].Geometry = location;
            //MapPoint location = new MapPoint(305737.67, 2740242.96, mapWells.SpatialReference);
            //wellsLayer.Graphics[0].Geometry = location;
is there any possibility or not to plot
DominiqueBroux
I am not sure to exactly understand what you mean.
In your last post, you are just trying to add graphics in a loop. That's obviously possible, there is a sample here:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AddGraphics
If I come back to the first posts :
  - it's possible to project multiple graphics by calling only once the project task : you just need to give the list of graphics as input of the task.
  - if, for any reason, you absolutely need to execute tasks in //, you have to instantiate new task objects. One single task doesn't support concurrent operation.
i am able to plot multiple point on my map code is attached
but one error occurs for the Input coordinate for multiple points only
MapPoint inputMapPoint = e.UserState as MapPoint;
resultGraphic.Attributes.Add("Input_Coordinate", inputMapPoint.X + "," + inputMapPoint.Y);
error Object reference not set to an instance of an object.
error prt screen is attached
void OnWebReadCompleted(object sender, OpenReadCompletedEventArgs e)
double ax = 0; double ay = 0; long az = 0;
while (i <= count)
graphics.Add(new Graphic() { Geometry = inputMapPoint });
i++;
void geometryService_ProjectCompleted(object sender, GraphicsEventArgs e)
int i;
for (i = 0; i < e.Results.Count; i++)
//e.Results.Count
Graphic resultGraphic = new Graphic();
resultGraphic = e.Results;
Graphic resultGraphic2 = new Graphic();
if (resultGraphic.Geometry.Extent != null)
resultGraphic.Symbol = LayoutRoot.Resources["RoundMarkerSymbol"] as SimpleMarkerSymbol;
MapPoint resultMapPoint = resultGraphic.Geometry as MapPoint;
resultGraphic.Attributes.Add("Output_Coordinate", resultMapPoint.X + "," + resultMapPoint.Y);
resultGraphic.Attributes.Add("Input_Coordinate", inputMapPoint.X + "," +inputMapPoint.Y);
graphicsLayer.Graphics.Add(resultGraphic);
else
MessageBox.Show("Invalid input coordinate, unable to project.");
