Adding MapTip in code-behind
1341
09-19-2012 12:44 AM
JohanCarlsson
Hi!
I'm new to programming with this API and I'm trying to add MapTip's dynamically where the user clicks.
I want to do everything in the code-behind since I'm working with the viewer and can't initialize any new maps in the XAML.
Here's what I got so far, code is executed in the order below:
Creating the layer:
GraphicsLayer mapTipLayer = new GraphicsLayer();                 mapTipLayer.ID = "mapTipLayer"; MapApplication.Current.Map.Layers.Add(mapTipLayer); MapApplication.SetLayerName(mapTipLayer, "MapTip Layer");
Setting a DefaultSymbol where the user clicks:
ESRI.ArcGIS.Client.Graphic g = new ESRI.ArcGIS.Client.Graphic() {      Geometry = mapPoint,      Symbol = LayoutRoot.Resources["DefaultMapTipSymbol"] as Symbol, }; mapTipLayer.Graphics.Add(g);
Everything works fine so far, the problems start when I try to use the MapTip-class. The graphic I addshows up but there's no hover function that displays anything.
ESRI.ArcGIS.Client.Toolkit.MapTip mapTip = new ESRI.ArcGIS.Client.Toolkit.MapTip(); mapTip.GraphicsLayer = mapTipLayer; mapTip.Title = "Some content"; mapTipLayer.MapTip = mapTip;
Am I doing it in the wrong order? Am I missing something? If I understood the API reference correctly this should be enough to display a MapTip. Should I add all MapTips before I add the layer to the current map? Should I use a FeatureLayer instead?
I've also tried this instead for the first code block:
mapTipLayer = new GraphicsLayer();                 mapTipLayer.ID = "mapTipLayer"; mapTipLayer.MapTip = new ESRI.ArcGIS.Client.Toolkit.MapTip() { Title = "test" }; MapApplication.Current.Map.Layers.Add(mapTipLayer); MapApplication.SetLayerName(mapTipLayer, "MapTip Layer");
Any suggestions, tips or references to similiar problems would be greatly appreciated.
Regards
Johan Carlsson
DominiqueBroux
Esri Frequent Contributor
To get maptips, you can either use the maptip control or set the maptip property of the layer. But don't do both.
Removing the latest line of your code shoudl work:
///mapTipLayer.MapTip = mapTip;[/CODE]
JohanCarlsson
I scrapped this approach, it was too troublesome. In a fraction of the time I implemented a simple MouseEnter and MouseLeave to create something similar to a MapTip.
DominiqueBroux
JohanCarlsson
Thank you Dominique, that solved the problem. Alot less code to maintain now.
I forgot another cruicial thing though, assigning the MapTip to the symbol (g.MapTip = mapTip).
Is there any way to loop through all of my MapTips and keep them visible indefinitely? The reason I want to implement this is because when we want to print the maps, we won't have any visible notes.
Edit:
To make things clearer, I'd like to click on the symbol I placed and that will launch a function that sets the HideDelay of the MapTip to infinity, through code-behind.
Regards
Johan Carlsson
