Adding Mapservice Programatically
3093
11
11-18-2013 12:18 AM
praveennarayandas
I am trying to add mapservice programatically.but it is not displaying map.
kindly letme know where i am doing wrong?
i have taken simple map application
My xaml code:
<esri:Map x:Name="MyMap" Background="White"  WrapAround="True" >
            <esri:ArcGISTiledMapServiceLayer x:Name="BaseMap" ID="BaseMap" Opacity="50"
                Initialized="MapServiceLayer_Initialized" InitializationFailed="Layer_InitializationFailed" />
        </esri:Map>
cs code:
            ArcGISTiledMapServiceLayer baseMap = new ArcGISTiledMapServiceLayer();
            String BaseMapResturl = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer";
            baseMap.Url = App._compentDict["BaseMapRestUrl"];
            baseMap.ID = "BaseMap";
            baseMap.Opacity = 50;
            baseMap.Initialized +=MapServiceLayer_Initialized;
            baseMap.InitializationFailed += MapServiceLayer_InitializationFailed;
            MyMap.Layers.Add(baseMap);
kindly let me where i am doing wrong.
thanks in advance.
praveen
JohanCarlsson
What does the error message say?
praveennarayandas
The Error msg is
"The Best Overloaded method match for 'string.this[int]' has some invalid arguments"
thanks for support.
DenisT
What is _compentDict?
praveennarayandas
it is a static variable using to store url
DenisT
Then why do you need this line?
Maybe it's better to post the entire code and point the line that throws an exception.
praveennarayandas
Sorry For confusion in the source code.
Here I am attaching complete source code.
XAML:
<UserControl
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009" x:Class="silverlightmap.MainPage"
    mc:Ignorable="d"
    d:DesignHeight="300" d:DesignWidth="400">
    <Grid x:Name="LayoutRoot" Background="White">
        </esri:Map>
    </Grid>
</UserControl>
.cs source code:
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using ESRI.ArcGIS.Client;
namespace silverlightmap
    public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
            baseMap.Initialized += MapServiceLayer_Initialized;
        private void MapServiceLayer_InitializationFailed(object sender, EventArgs e)
            throw new NotImplementedException();
        private void MapServiceLayer_Initialized(object sender, EventArgs e)
kindly let me know where i am doing wrong.
thanks a lot for support.
praveennarayandas
at line number 23 i am getting the error
Error 1 The best overloaded method match for 'string.this[int]' has some invalid arguments C:\inetpub\wwwroot\silverlightmap\silverlightmap\MainPage.xaml.cs 23 27 silverlightmap
DenisT
Missing App.xaml.cs content.
praveennarayandas
App.xaml.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
    public partial class App : Application
        public static string _compentDict;
        public App()
            this.Startup += this.Application_Startup;
            this.Exit += this.Application_Exit;
            this.UnhandledException += this.Application_UnhandledException;
        private void Application_Startup(object sender, StartupEventArgs e)
            this.RootVisual = new MainPage();
        private void Application_Exit(object sender, EventArgs e)
        private void Application_UnhandledException(object sender, ApplicationUnhandledExceptionEventArgs e)
            // If the app is running outside of the debugger then report the exception using
            // the browser's exception mechanism. On IE this will display it a yellow alert
            // icon in the status bar and Firefox will display a script error.
            if (!System.Diagnostics.Debugger.IsAttached)
                // NOTE: This will allow the application to continue running after an exception has been thrown
                // but not handled.
                // For production applications this error handling should be replaced with something that will
                // report the error to the website and stop the application.
                e.Handled = true;
                Deployment.Current.Dispatcher.BeginInvoke(delegate { ReportErrorToDOM(e); });
        private void ReportErrorToDOM(ApplicationUnhandledExceptionEventArgs e)
            try
                string errorMsg = e.ExceptionObject.Message + e.ExceptionObject.StackTrace;
                errorMsg = errorMsg.Replace('"', '\'').Replace("\r\n", @"\n");
                System.Windows.Browser.HtmlPage.Window.Eval("throw new Error(\"Unhandled Error in Silverlight Application " + errorMsg + "\");");
            catch (Exception)
        public static string _ { get; set; }
