adding map service url
1123
11-18-2013 07:18 PM
rakeshmenga
hi,
i am trying to add mapservice through programtically (NOT XAML) through code behind in a simple
webmap application. here i am able to read the service Background.Child but not able to bind it to mapcontrol
code i have used is
((ESRI.ArcGIS.Client.ArcGISTiledMapServiceLayer)((new List<ESRI.ArcGIS.Client.Layer>(((ESRI.ArcGIS.Client.Map)(BackgroundBorder.Child)).Layers))[0])).Url = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer";
Error;
"Index was out of range. Must be non-negative and less than the size of the collection"
kindly let me know any solution for this.
thanks in advance.
rakesh
JohanCarlsson
Try this
ArcGISTiledMapServiceLayer tiles = new ArcGISTiledMapServiceLayer()
    Url = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer/0"
MapApplication.Current.Map.Layers.Add(tiles);
MapApplication.SetLayerName(tiles, "World Street Map");
EDIT:
The layer you are trying  to add is as feature layer, so you might want to try FeatureLayer instead of ArcGISTiledMapServiceLayer.
DenisT
Add an x:Name attribute to Map in xaml, then use that name to access the map in the code-behind file.
There is a samples page for SL API.
