adding graphic on polygon label points
1124
09-20-2011 11:10 AM
SangamLama
I'm trying add graphics (small dots) on some polygons. I use LabelPoints function (of GeometryService) to find out the point where I should add these graphics. When the map view is on its full extent, it seems as if the points weren't added inside the polygon. The respective graphics show up within (and close to the center of) the polygon only when I zoom in to the polygons.
Is this normal? Or should I play with the SetZIndex function? or is it some other adjustment I need to make?
DominiqueBroux
Esri Frequent Contributor
I am not sure to understand but if your symbol doesn't look at the same location when you zoom out, it's perhaps an issue with the symbol that could be drawn with an offset.
Which symbol are you using?
SangamLama
good catch! I had the offset values set for the picturemarkersymbol I was using for labels..
thanks
