Adding addition points of interest
951
03-17-2011 04:39 AM
BrianCook
1. Is it possible to add custom location sbased on Lat/Long?
2. If so then can it be added with either a SQL databasee or XML file inport at runtime?
THanks,
DominiqueBroux
Esri Frequent Contributor
Yes, you can create a GraphicsLayer and add by code a graphic corresponding to your custom location. If your map is not in Geographical coordinates, you will have to project your Lat/long into the spatial reference of the map.
Yes both are possible.
From a SQL DataBase you will need MapIt at the server side (or ArcGIS Server) : see a sample here : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SDSFeatureLayer
From a XML file, you can look at the GeoRss sample : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#GeoRssSimple
