Add Rows to datagrid at runtime
2017
05-20-2010 06:12 AM
AndrewChap
I have a datagrid view that will hold results from varying layers from a map service using querytask/query.
When I get the results, I want to populate the datagridcolumns on the fly as well as adding the new data.
The code I am using yields only empty data row without the feature set's values.
Any suggestions?
chap
void queryTask_ExecuteCompleted(object sender, QueryEventArgs e)
            dg.ItemsSource = null;
            dg.Columns.Clear();
            FeatureSet featureSet = e.FeatureSet;
            List<string> fields = new List<string>();
            // add columns
            foreach (var item in featureSet.FieldAliases)
                fields.Add(item.Value);
                dg.Columns.Add(new DataGridTextColumn()
                    Header = item.Value,
                   Binding = new Binding(item.Value)
            dg.ItemsSource = GenerateData(fields, featureSet);
        public IEnumerable<IDictionary> GenerateData(List<string> fields, FeatureSet fs)
            for (var i = 0; i < fs.Features.Count; i++)
                var dict = new Dictionary<string, object>();
                foreach (var field in fields)
                    dict[field] = (fs.Features.Attributes[field]);
                yield return dict;
dotMorten_esri
Esri Notable Contributor
If you are using the FeatureDataGrid, do not use the ItemsSource. Instead set the GraphicsLayer property to a GraphicsLayer that holds your results.
The other approach is to use Silverlight's core DataGrid, like shown here: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryWithoutMap
Judging from your sample above, your binding expression doesn't look right. Compare to the xaml in the above link.
DominiqueBroux
Esri Frequent Contributor
Hi ChapScribe,
In your code you are supposed to bind to a dictionary. So I suggest you change your code 'Binding = new Binding(item.Value)' by 'Binding = new Binding("[" + item.Value + "]")'.
Note : this is only working with SL4. With previous version, you have to use the Dictionary converter.
