Add Functionality to FeatureDataGrid
1627
6
12-06-2011 06:59 AM
KeithGanzenmuller
I have a featuredatagrid which displays information for selected parcels.
I want to add a button to it that exports the information for the parcels that are selected in the featuredatagrid.
I can export the info using a button but I would like to add the button to the bottom of the grid near the options button or add a menu item to the options menu.
I have edited the control templates before but it has been to remove or change the properties of the control parts. I can also navigate down to the to the parts by editing the controls template...so my question is if I add a button...here comes the dumb part...where does the code go for the click event functionality.
Thanks for any help or suggestions.
Keith
DominiqueBroux
Esri Frequent Contributor
You can create your own control subclassing FeatureDataGrid.
Something like:
public class MyFeatureDataGrid : ESRI.ArcGIS.Client.Toolkit.FeatureDataGrid
  public override void OnApplyTemplate()
    base.OnApplyTemplate();
    var myNewButton = GetTemplateChild("MyNewButton") as Button;
    if (myNewButton != null)
      myNewButton.Click += myNewButton_Click;
  void myNewButton_Click(object sender, System.Windows.RoutedEventArgs e)
    // TODO
    throw new System.NotImplementedException();
Then you have to edit the template and add a button called "MyNewButton" (as you already done).
And finally you have to use this subclass in your xaml main control.
KeithGanzenmuller
Thanks Dominique, that is exactly what I need to do.
Anyone have similar code for VB?
KeithGanzenmuller
I subclassed ( I think) the FeatureDataGrid, added it in XAML.
The FDG receives the output of my selections perfectly.
I added an Export Selected button named "ExportButton" to the Options Popup Menus. The button appears in the menu when I run the project and click "Options".
Partial XAML of Options popup below:
<Grid Margin="5,0,0,0">
<Button x:Name="OptionsButton" Content=" Options... "/>
<Popup x:Name="PopupMenu" IsOpen="False">
<Border BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="1" Background="TemplateBinding Background}" CornerRadius="1.5">
<StackPanel>                 <Button x:Name="ExportButton" Margin="5,0" Style="{StaticResource MenuButtonStyle}">
<TextBlock Margin="5" Text="Export Selection" VerticalAlignment="Center"/>
</Button>
My question is, inside my subclass, in VB .Net, how do I find my button to assign it's click event?
Thanks for any suggestions.
KeithGanzenmuller
This is what the class looks like:
So far I am trying to run the code and find the button but it always returns nothing.
Public Class NewFDG
    Inherits ESRI.ArcGIS.Client.Toolkit.FeatureDataGrid
    Public Sub New()
        MyBase.New()
        Dim myexportButton As Button = CType(GetTemplateChild("ExportSelectionButton"), Button)
        '    AddHandler myexportButton.Click, AddressOf myexportButton_Click
If myexportButton Is Nothing Then
           MessageBox.Show("Nothing")
End If
    End Sub
    'Private Sub myexportButton_Click(sender As Object, e As RoutedEventArgs)
    '    MessageBox.Show("Click") 'Throw New NotImplementedException
    'End Sub
End Class
DominiqueBroux
You can't call GetTemplateChild in the constructor.
You have to do it by overriding OnApplyTemplate.
Something like:
Public Overrides Sub OnApplyTemplate()
  MyBase.OnApplyTemplate()
  Dim myNewButton = TryCast(GetTemplateChild("MyNewButton"), Button)
  If myNewButton IsNot Nothing Then
End If
End Sub
KeithGanzenmuller
That worked PERFECTLY, the code found the button and executed the click event.
Thanks again to you.
