Accessing VisualStateManager
1176
12-09-2011 05:44 AM
oo
<esri:SimpleRenderer x:Key="MySimpleRendererLines">
                <esri:SimpleRenderer.Symbol>
                    <esri:LineSymbol>
                        <esri:LineSymbol.ControlTemplate>
                            <ControlTemplate>
                                <Grid>
                                    <VisualStateManager.VisualStateGroups>
                                        <VisualStateGroup x:Name="CommonStates">
                                            <VisualState x:Name="MouseOver">
                                                <Storyboard>
                                                    <DoubleAnimation Storyboard.TargetName="Element" Storyboard.TargetProperty="(Shape.StrokeThickness)" BeginTime="0" Duration="00:00:00" To="6" />
                                                </Storyboard>
                                            </VisualState>
                                            <VisualState x:Name="Normal">
                                                <Storyboard>
                                                    <DoubleAnimation Storyboard.TargetName="Element" Storyboard.TargetProperty="(Shape.StrokeThickness)" BeginTime="0" Duration="00:00:00" To="2" />
                                                </Storyboard>
                                            </VisualState>
                                            <VisualState x:Name="Selected">
                                                <Storyboard>
                                                    <DoubleAnimation Storyboard.TargetName="Element" Storyboard.TargetProperty="(Shape.StrokeThickness)" BeginTime="0" Duration="00:00:00" To="6"/>
                                                </Storyboard>
                                            </VisualState>
                                        </VisualStateGroup>
                                    </VisualStateManager.VisualStateGroups>
                                    <Path x:Name="Element" Stroke="Black" StrokeThickness="2" />
                                </Grid>
                            </ControlTemplate>
                        </esri:LineSymbol.ControlTemplate>
                    </esri:LineSymbol>
                </esri:SimpleRenderer.Symbol>
            </esri:SimpleRenderer>
I have the above Renderer in my xaml and would like to change the VisualState of a Symbol programmatically like this:
VisualStateManager.GoToState(_MySymbol, "Normal", true);
My problem is, I have not found a way to access the VisualStateManager (so far I can only access the ControlTemplate via
SimpleRenderer sr = LayoutRoot.Resources["MySimpleRendererLines"] as SimpleRenderer;
ControlTemplate ct = sr.Symbol.ControlTemplate;
Thanks for your help!
DominiqueBroux
Esri Frequent Contributor
AFAIK it's not possible.
Not sure why you want to access the VisualStatemanager but note that your symbol is wrong.
You have to define 2 VisualStateGroups : 'CommonStates' and 'SelectionStates' with respectively the states ('Normal', 'MouseOver') and ('Selected', 'Unselected'). Once defined, the state changes will be managed by the SL API.
