Accessing Attribute Indexes
2859
06-20-2011 01:36 AM
MichaelMelaku
Salute All,
Well, i got a requirement to pass an attribute index as a queryString and perform a query operation at the backend. This numeric value should then be parsed to give the attribute name so that i can use it for the queryTask while passing the string URL as a parameter to construct the querytask.
My question is ... is it possible to get an attribute index and parse it to get the attribute name from the application logic? Please any code snippet or conceptual brief would certainly help.
DominiqueBroux
Esri Frequent Contributor
A FeatureLayer is providing the 'LayerInfo' property whose 'Fields' property is returning the list of fields ans so a way to index all the fields.
So the FeatureLayer seems to be what you are looking for. Even if you don't need the FeatureLayer in your map, you can create one by code just in order to get the list of fields. In this case, instantiate the feature layer, set the URL and call 'Initialize'. On event 'Initialized' we'll be able to get the list of fields.
MichaelMelaku
Thanks Dominique. That was very helpful. Let me put it in place and see how it goes. I'll let u know.
MichaelMelaku
Well, Strange. For some reasons, the LayerInfo of the featurelayer is always returning null. I don't know what i'm missing. For review, the below is my snippet.
Private void IndexExtractor()
     FeatureLayer ft = new FeatureLayer()
            ID = "MyFeatureLayer",
            Url = "http://michael/ArcGIS/rest/services/zones/FeatureServer/1"
     ft.Initalized += new EventHandler<EventArgs>(ft_Initalized);
     Map.Layers.Add(ft);
     List<ESRI.ArcGIS.Client.Field> LayerFields = new List<ESRI.ArcGIS.Client.Field>();
     ESRI.ArcGIS.Client.FeatureService.FeatureLayerInfo myFeatureLayerInfo = ft.LayerInfo;
     foreach (ESRI.ArcGIS.Client.Field Fields in myFeatureLayerInfo.Fields)
          LayerFields.Add(Fields);
void ft_Initalized(object sender, EventArgs e)
     ft.Initalize();
     Graphic newGraphic = new Graphic();
     ft.Graphics.Add(newGraphic);
Everytime it executes, the LayerInfo returns null. Any idea?
Thanks a mil.
DominiqueBroux
The LayerInfo is only available after the layer has been initialized.
So this should be not null in ft_initialized.
Side note : since you are adding your layer in a map, it's not useful to call Initialize on it :
FeatureLayer ft = sender as FeatureLayer;
////ft.Initalize(); Not needed
Graphic newGraphic = new Graphic(); // need to add geometry here
///ft.LayerInfo  should be non null here
