2.1 Beta double encodes 'imageSR' and 'bboxSR' parameters
1804
11-15-2010 01:21 PM
JasonScharf
Greetings,
I'm using the new 2.1 API for Silverlight/WPF and I've noticed that the imageSR and bboxSR parameters (and maybe more) happen to have been encoded twice by the API. Example:
bbox=13411824.8287484%2c385003.362371264%2c13418421.0112482%2c390910.15762643&size=421%2c377&format=png8&transparent=true&layers=show%3a0%2c1&imageSR=%257b%2522wkt%2522%253a%2522PROJCS%255b%255c%2522NAD_1983_Lambert_Conformal_Conic%255c%2522%252c%2bGEOGCS%255b%255c%2522GCS_North_American_1983%255c%2522%252c%2bDATUM%255b%255c%2522D_North_American_1983%255c%2522%252c%2bSPHEROID%255b%255c%2522GRS_1980%255c%2522%252c%2b6378137%252c%2b298.257222101%255d%255d%252c%2bPRIMEM%255b%255c%2522Greenwich%255c%2522%252c%2b0%255d%252c%2bUNIT%255b%255c%2522Degree%255c%2522%252c%2b0.0174532925199433%255d%255d%252c%2bPROJECTION%255b%255c%2522Lambert_Conformal_Conic%255c%2522%255d%252c%2bPARAMETER%255b%255c%2522False_Easting%255c%2522%252c%2b13123359.5800525%255d%252c%2bPARAMETER%255b%255c%2522False_Northing%255c%2522%252c%2b0%255d%252c%2bPARAMETER%255b%255c%2522Central_Meridian%255c%2522%252c%2b-84.3666666666667%255d%252c%2bPARAMETER%255b%255c%2522Standard_Parallel_1%255c%2522%252c%2b42.1%255d%252c%2bPARAMETER%255b%255c%2522Standard_Parallel_2%255c%2522%252c%2b43.6666666666667%255d%252c%2bPARAMETER%255b%255c%2522Latitude_Of_Origin%255c%2522%252c%2b41.5%255d%252c%2bUNIT%255b%255c%2522Foot%255c%2522%252c%2b0.3048%255d%255d%2522%257d&bboxSR=%257b%2522wkt%2522%253a%2522PROJCS%255b%255c%2522NAD_1983_Lambert_Conformal_Conic%255c%2522%252c%2bGEOGCS%255b%255c%2522GCS_North_American_1983%255c%2522%252c%2bDATUM%255b%255c%2522D_North_American_1983%255c%2522%252c%2bSPHEROID%255b%255c%2522GRS_1980%255c%2522%252c%2b6378137%252c%2b298.257222101%255d%255d%252c%2bPRIMEM%255b%255c%2522Greenwich%255c%2522%252c%2b0%255d%252c%2bUNIT%255b%255c%2522Degree%255c%2522%252c%2b0.0174532925199433%255d%255d%252c%2bPROJECTION%255b%255c%2522Lambert_Conformal_Conic%255c%2522%255d%252c%2bPARAMETER%255b%255c%2522False_Easting%255c%2522%252c%2b13123359.5800525%255d%252c%2bPARAMETER%255b%255c%2522False_Northing%255c%2522%252c%2b0%255d%252c%2bPARAMETER%255b%255c%2522Central_Meridian%255c%2522%252c%2b-84.3666666666667%255d%252c%2bPARAMETER%255b%255c%2522Standard_Parallel_1%255c%2522%252c%2b42.1%255d%252c%2bPARAMETER%255b%255c%2522Standard_Parallel_2%255c%2522%252c%2b43.6666666666667%255d%252c%2bPARAMETER%255b%255c%2522Latitude_Of_Origin%255c%2522%252c%2b41.5%255d%252c%2bUNIT%255b%255c%2522Foot%255c%2522%252c%2b0.3048%255d%255d%2522%257d&f=image
Cheers,
JS
JasonScharf
Also, it may be worth mentioning that the resulting response was a 404 which was initially misleading:
HTTP/1.1 404 'imageSR' parameter is invalid
DominiqueBroux
Esri Frequent Contributor
This bug was existing in the beta but is supposed to be fixed in the release candidate (build 427).
Which version are you using?
If it's not the RC, could you try after downloading it here : http://resources.arcgis.com/content/how-download-arcgis-api-microsoft-silverlightwpf-beta
Thanks
JasonScharf
I can confirm it has been fixed in the RC. Thanks!
DominiqueBroux
Thanks for your confirmation. Good to know.
SergioGalindo
Im using 2.1 (not beta) and it looks like it still does it (i mean the comma's double encoding):
http://mps.prosis.com/sigmps/proxy.ashx?http%3a%2f%2fmps.prosis.com%2fArcGIS%2frest%2fservices%2fMPS_Proteccion_Social%2fMapServer%2fexport%3fbbox%3d-8270075.29231198%252c504785.204638491%252c-8218957.58845141%252c527257.420547742%26size%3d1358%252c597%26format%3dpng24%26transparent%3dtrue%26imageSR%3d102100%26bboxSR%3d102100%26f%3dimage%26
any way to avoid this?
Thanks
