10.1 printing with TextSymbols
1585
01-14-2013 06:07 AM
YamunadeviRathinasamy
I have some graphics with textsymbol on a graphicslayer which also has list of attributes.
If I try printing the print result is null. I removed all the attributes of the graphic except "OBJECTID" then print works with textsymbol.
tomw
I have the issue too. Is esri going to fix this issue in a next service pack?
Tom
JohanCarlsson
Same error here. Adding attributes to a TextSymbol causes the print to fail.
Any updates on this?
Edit: Is there any thread or other official channel where you can see and follow known bugs? This would probably eliminate a lot of forum threads.
ShaharBukra
there is open NIM on this subject
you can see more details in this thread :
http://forums.arcgis.com/threads/75263-Print-TextSymbol
did anyone tried to send the print more then one graphic layer with different geometry? (polygon and polyline together...)
i get the following error
Mix geometry types are not supported.
Parameter name: Graphics
JohanCarlsson
Shahar, that is a known limitation. You have to separate each type on different layers.
