Unable to read parquet file with arcgis per docs?
1803
05-10-2023 11:34 AM
CarlSunderman
I understand that I can read the parquet file in pandas, but why does the documentation claim you can read into a spatial dataframe when you cannot?
The docs claim, new in version 1.9 and I'm using arcgis version 2.0.1
This is from the docs:
static from_parquet(path, columns=None, **kwargs)
Load a Parquet object from the file path, returning a Spatially Enabled DataFrame.
Returns
>>> df = pd.DataFrame.spatial.read_parquet("data.parquet")
https://developers.arcgis.com/python/api-reference/arcgis.features.toc.html?
but every time I try to read a parquet file, i get the same error
AttributeError: type object 'GeoAccessor' has no attribute 'read_parquet'
Why not remove it from the docs if you cannot read a parquet file?
I
EarlMedina
Hi @CarlSunderman ,
I read the from_parquet documentation and I believe it may need to be updated. It states:
if no geometry columns are read, this will raise a ValueError - you should use the pandas read_parquet method instead.
My reading of this is you should use the standard pandas.read_parquet method, completely separate from GeoAccessor. This makes sense because if you have no geometry column(s) in your data, then you are working with non-spatial data.
Of course, later on the User is told to do this:
This seems to contradict the previous statement. If you have spatial data, then you should be using pd.DataFrame.spatial.from_parquet.
So, to read non-spatial parquet data use:
pd.read_parquet(your_parquet_file_path)
Hope this helps clear up some confusion. I think submitting feedback on the documentation is in order.
