SelctbyAttributes
3600
7
05-11-2020 11:52 AM
jaykapalczynski
Honored Contributor
Where am I going wrong here.
countiesFeatureClass = r"E:/ArcGISProjects/CountySelection/[email protected]/Counties_1_Dissolved"
queryCounties = arcpy.SelectLayerByAttribute_management(countiesFeatureClass,
                                                        'NEW_SELECTION',
                                                        '"FIPS2"=3 OR "FIPS2"=12')
# Write the selected features to a new featureclass
arcpy.CopyFeatures_management(queryCounties, 'countiesSelected')
File "E:\ArcGISProjects\CountySelection\Python\Update_v4.py", line 32, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\management.py", line 7744, in SelectLayerByAttribute
raise e
ExecuteError: Failed to execute. Parameters are not valid.
The value cannot be a feature class
ERROR 000840: The value is not a Raster Layer.
ERROR 000840: The value is not a Mosaic Layer.
Failed to execute (SelectLayerByAttribute).
JoshuaBixby
Oh,  you should be using Select Layer By Attribute and not Select Layer by Location.  You are passing the syntax for one into the other.
jaykapalczynski
Honored Contributor
Trying this as well...same similar error...seems to be in the syntax of the where clause...
# DEFINE THE COUNTIES FC
arcpy.MakeFeatureLayer_management(r"E:/Projects/County/xxxx.sde/Counties", "counties_lyr")
# SELECT FROM BUFFER PUT INTO RESULTS VARIABLE
results = arcpy.SelectLayerByLocation_management('counties_lyr', 'NEW_SELECTION', 'FIPS2 > 16')
# GET THE FIPS CODES FROM THE RESULTS OF THE SELECTION
rows = arcpy.SearchCursor(results,"","","FIPS2")
for row in rows:
    neighborVal = str(row.FIPS2)
    print(neighborVal)
jaykapalczynski
Honored Contributor
Note this is a Feature Class in n SDE SQL db
results = arcpy.SelectLayerByLocation_management("counties_lyr",
                                         "NEW_SELECTION",
                                         "[FURST_JURI]='ACCOMACK'")‍‍‍‍‍‍‍
Ive tried this for Text field
"[FURST_JURI]='ACCOMACK' "
"FIRST_JURI = 'ACCOMACK' "
' "FIRST_JURI" = 'ACCOMACK' "
Ive tried for Int
"FIPS2 > 1"
' "FIPS2" > 1'
"[FIPS2] > 1"
I know the attributes and values exist
JoshuaBixby
Given the error message and the fact that you are using some enterprise geodatabase, I would start by dropping the double quotes around your field names:
'FIPS2 = 3 OR FIPS2 = 12'
jaykapalczynski
Honored Contributor
results = arcpy.SelectLayerByLocation_management("counties_lyr", "NEW_SELECTION", 'FIPS2 = 3 OR FIPS2 = 12')
ERROR
JoshuaBixby
jaykapalczynski
Honored Contributor
For crying out loud....ahhahahahha...
Thats what you get from copy and paste form other Python scripts...ahahah
THANKS for the extra set of eyes.....thats embarrassing
JoshuaBixby
No worries, it happens to all of us from time to time.  Your original code snippet was Select Layer By Attribute, but then you switched to calling Select Layer By Location in follow-up troubleshooting.  For certain data sources, putting a field name in double quotes implicitly tells ArcGIS that you are looking for a raster data set, which I think is the cause of your initial error.
