Publishing CSV in ArcGIS Online with publish_parameters fails
918
11-18-2025 12:41 PM
JACooper
I recently switched my workflow from using `gis.content.add()` to `Folder.add()`, as the future warnings have been advising. I have one workflow that publishes a non-spatial CSV to a hosted table to ArcGIS Online that I believe was working as recently as last week with the new `arcgis==2.4.2` version. This week, however, trying to publish with any non-null `publish_parameters` argument at all is resulting in a hallucination of the item already existing in the organization. I have tested with various datasets and item names (including item names never before used for the organization), and all have come back with this exception. Any publish parameter will trigger this for me (time zone, type, location type). Publishing without the argument or with a blank dictionary does not trigger this issue, but it will geocode any location fields and cost me credits, which is the point of setting `{"locationType": "none"}` for tables.
Here's a stripped down version that trigger the error for me. Just enter your own credentials, ensure you have arcgis==2.4.2 installed, and execute. My error messages are at the bottom of the code block, environment specs after that. Let me know if I've missed anything. Thanks, all!
import os, sys, arcgis, pandas as pd, time
df = pd.DataFrame({"state": ["Wyoming"]})
downloads = os.path.join(os.path.expanduser("~"), "Downloads")
tstcsvname = "test_csv"
tst_path = os.path.join(downloads, f"{tstcsvname}.csv")
df.to_csv(tst_path, index=False)
# Enter your own username and password here:
uname =
pwrd =
gis = arcgis.GIS(url="https://www.arcgis.com", username=uname, password=pwrd)
# Get the folder
user = gis.users.me
target_folder = [f for f in user.folders if f.properties["id"] == "Root Folder"][0]
counter = 0
for pp in [None, {"locationType": "none"}]:
    # Check to make sure the CSV/Feature layer isn't there already.
    remote = None
    for itype in ["CSV", "Feature Service"]:
        search = gis.content.search(
            query=f'title: "{tstcsvname}", type: "{itype}"', max_items=1
        if search:
            # If it is, remove it fully for a clean, fresh execution.
            remote = search[0]
            print("Deleting")
            print(remote)
            remote.delete(permanent=True)
    del remote
    # Add test data file
    props = {"title": tstcsvname, "type": "CSV"}
    job = target_folder.add(item_properties=props, file=tst_path)
    remotecsv = job.result()
    # remotecsv = gis.content.add(item_properties=props,file=tst_path)  # This loads a corrupted CSV; not sure what this is about...
    print(remotecsv)
    time.sleep(1.5)
    if not pp:
        # Try 1: Publishing works here
        # WARNING! This will use credits to geocode 1 record
        remotecsv.publish()
        print("Successful publishing without publish_parameters")
        # Woops, that geocoded when I didn't mean for it to. Let's use publish_parameters to avoid that.
    else:
        # Try 2: But if you toggle to this option, it does not.
        print("Try to publish with publish parameters")
        # pp = {"locationType": "none"}
        remotecsv.publish(publish_parameters=pp)
        # arcgis==2.4.1.1
        # Traceback (most recent call last):
        #   File "~\Downloads\publish_parameters_error.py", line 21, in <module>
        #     remotecsv.publish(publish_parameters=pp)
        #   File "~\Python311\site-packages\arcgis\gis\__init__.py", line 16825, in publish
        #     return self._publish(**params)
        #   File "~\Python311\site-packages\arcgis\gis\__init__.py", line 17111, in _publish
        #     raise Exception("Service name already exists in your org.")
        # Exception: Service name already exists in your org.
        # arcgis==2.4.2
        #   File "~\Downloads\publish_parameters_error.py", line 27, in <module>
        #   File "C~\Lib\site-packages\arcgis\gis\__init__.py", line 17877, in publish
        #   File "~\Lib\site-packages\arcgis\gis\__init__.py", line 18164, in _publish
    print()
System: Windows 11 (2 machines tested)
Python versions tested: 3.11.8, 3.12.4, & 3.12.10
`arcgis` package versions tested: 2.4.1.1 & 2.4.2
`pip freeze`:
annotated-types==0.7.0
arcgis==2.4.2
cachetools==6.2.2
certifi==2025.11.12
cffi==2.0.0
charset-normalizer==3.4.4
click==8.3.1
cloudpickle==3.1.2
colorama==0.4.6
contourpy==1.3.3
cryptography==46.0.3
cycler==0.12.1
dask==2025.2.0
fonttools==4.60.1
fsspec==2025.10.0
geomet==1.1.0
idna==3.11
jaraco.classes==3.4.0
jaraco.context==6.0.1
jaraco.functools==4.3.0
keyring==25.7.0
kiwisolver==1.4.9
locket==1.0.0
lxml==6.0.2
matplotlib==3.10.7
matplotlib-inline==0.2.1
more-itertools==10.8.0
networkx==3.5
numpy==2.3.5
oauthlib==3.3.1
packaging==25.0
pandas==2.3.3
partd==1.4.2
pillow==12.0.0
puremagic==1.30
pyarrow==20.0.0
pycparser==2.23
pydantic==2.12.4
pydantic_core==2.41.5
pylerc==4.0
pyparsing==3.2.5
pyspnego==0.12.0
python-dateutil==2.9.0.post0
pytz==2025.2
pywin32==311
pywin32-ctypes==0.2.3
PyYAML==6.0.3
requests==2.32.5
requests-oauthlib==2.0.0
requests-toolbelt==1.0.0
six==1.17.0
sspilib==0.4.0
toolz==1.1.0
traitlets==5.14.3
truststore==0.10.4
typing-inspection==0.4.2
typing_extensions==4.15.0
tzdata==2025.2
ujson==5.11.0
urllib3==2.5.0
websocket-client==1.9.0
Clubdebambos
MVP Regular Contributor
Hi @JACooper,
This works for me. Code commented...
from arcgis.gis import GIS, ItemProperties, ItemTypeEnum
## Access AGOL
agol = GIS("home")
## The filepath to the csv file
csv_filepath = "path/to/file.csv"
## Get the folder
target_folder = agol.content.folders.get(None)
## Use the ItemProperties class to create an ItemProperties object
item_properties = ItemProperties(
    title = "TITLE_OF_CSV_ITEM",
    item_type = ItemTypeEnum.CSV.value,
    tags = ["PLACE", "TAGS", "HERE"],
    snippet = "THIS IS YOUR SUMMARY",
    description = "THIS IS YOUR DESCRIPTION"
## Add the Shapefile as an Item to the folder via the add() method for a folder object
csv_agol = target_folder.add(
    item_properties = item_properties,
    file = csv_filepath
).result()
print(csv_agol)
## Publish added CSV to Hosted Table Service
publish_parameters = {
    "type" : "csv",
    "name" : "NAME_OF_TABLE",
    "locationType" : "none"
niah_tbl = csv_agol.publish(
    publish_parameters=publish_parameters
print(niah_tbl)
print("\nSCRIPT COMPLETE")
Let me know if it works for you?
All the best,
Glen
~ learn.finaldraftmapping.com
