No module named 'arcgis' for import GIS
11185
8
08-20-2019 09:09 AM
Pa_Lotus
 I have ArcGIS API for Python installed and when I use below line, am getting error as
ModuleNotFoundError: No module named arcgis
from arcgis.gis import GIS
c
DanPatterson_Retired
import sys
sys.executable
'C:\\Your_ArcGISPro_install_path\\bin\\Python\\envs\\arcgispro-py3\\pythonw.exe'
# ---- arcgis is installed in
# C:\Your_ArcGISPro_install_path\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis‍‍‍‍‍‍‍‍‍
Do the sys.executable... if it isn't in the same path up and including
Then you are using the wrong python or arcgis was installed incorrectly.
Obviously Your_ArcGISPro_install_path will depend on your setup
JoshuaBixby
MVP Esteemed Contributor
Can you elaborate on how you installed ArcGIS API for Python?
Pa_Lotus
Joshua Bixby‌ Thank you for reply
I didn't install myself, my team member did, he said it comes with pro
and for import arcpy there is no error
Thanks
JoshuaBixby
ArcGIS Pro ships with 64-bit Python 3.6.8, and your screenshot shows 32-bit Python 3.7.3, so clearly this is not a typical/default installation.
Pa_Lotus
I logged in to My ArcgIS PRo, and in python section, i see version 1.4.1
is that right
Thanks
JoshuaBixby
Please respond to Dan's question.  As Dan suspects, and I agree with, it seems you are running a different Python distribution than the one bundled with Pro, and the Python distribution you are running doesn't have ArcGIS API for Python installed.
import sys
sys.executable
Pa_Lotus
Dan
My arcgis pro installed path is
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
and i installed pthon 3.7.3 that path is C:\python3.7.3\
my pyscripter python version in pyscripter is
and my python path is to C:\python3.7.3\  Not the Pro installed path
i tried to add path (C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3 ) in pyscripter it gets added and when i ran the script and the settings agian changes to default
can you suggest me
Thanks
That is a pyscripter problem, it isn't set up properly to use the required python.
