Labels not appearing on Web Map
806
11-02-2025 08:49 AM
DaleHarris3
I want to create a quick Webmap to preview some points from a database via pandas. The points display correctly, and they render correctly (diamond marker) but for the life of me I can't work out how to display labels on each of the points. Example code below:
#### Only for testing
from arcgis.gis import GIS
import pandas as pd
area = 'ARG'
data = {'name': ['Hole 1', 'Hole 2'],
        'x': [-66.3211, -66.3186],
        'y': [-24.3959, -24.3948]}
df = pd.DataFrame(data)
popup_info = {
    "title": "{name}", "description" : "{name}"
labelClass = {
  "showLabels": True,
  "renderer": {
    "type": "simple",
    "symbol": {
      "type": "esriSMS",
      "style": "esriSMSDiamond",
      "color": [
        255,
        0,
        0,
        200
      "size": 8,
      "angle": 0,
      "xoffset": 0,
      "yoffset": 0,
      "outline": {
        "color": [
          0,
          0,
          0,
          255
        "width": 1
  "labelingInfo": [
      "labelExpression": "",
        "labelExpressionInfo": {
          "expression": "$feature[\"name\"]",
          "value": "{name}"
      "symbol": {
        "type": "esriTS",
        "color": [
          78,
          78,
          78,
          255
        "backgroundColor": [
          0,
          0,
          0,
        "borderLineSize": 2,
        "borderLineColor": [
          255,
          0,
          255,
          255
        "haloSize": 2,
        "haloColor": [
          0,
          255,
          0,
          255
        "verticalAlignment": "bottom",
        "horizontalAlignment": "left",
        "rightToLeft": False,
        "angle": 0,
        "xoffset": 0,
        "yoffset": 0,
        "kerning": True,
        "font": {
          "family": "Arial",
          "size": 12,
          "style": "normal",
          "weight": "bold",
          "decoration": "none"
gis = GIS("home")
sdf = pd.DataFrame.spatial.from_xy(df, x_column='x', y_column='y')
map_widget = gis.map(area)
map_widget.content.add(sdf, options={'opacity':0.75},popup_info=popup_info, drawing_info=labelClass)
display(map_widget)
Clubdebambos
MVP Regular Contributor
You can try adding the showLabels property at the layer level instead of the drawinInfo.
map_widget.content.add(sdf, options={'opacity':0.75, 'showLabels' : True},popup_info=popup_info, drawing_info=labelClass)
~ learn.finaldraftmapping.com
JohnButcher
Hi there,
Came across this post and I'm wondering if you ever found a solution. I seem to having the same problem.
Thanks!
