J'ai une couche d'entités polygonale que je voudrais numeroter automatiquement mais en spiral (En escargot). De facon à avoir une continuité par voisinage. je suis un debutant en python, merci de m'aider. Merci
12604
26
02-21-2018 12:42 PM
NedCharles
J'ai une couche d'entités polygonale que je voudrais numéroter automatiquement mais en spirale (En escargot). De facon à avoir une continuité par voisinage. je suis un débutant en python, merci de m'aider. Merci
DanPatterson_Retired
I see, you want to flip between max Y and max X and min Y and min X pairs.  A Peano sort won't cut it.  I suspect you will have to generate the spiral from the centre with a repeating angle and an increasing distance increment.  The rate at which the distance from the centre changes (ie what function, if any, sin, cos etc) will determine the shape of the spiral.
I am sure it has a name, but the market for spiral generation outside of mazes and shellfish is somewhat limited
Although a reversed squished Archimede's spiral looks promising https://en.wikipedia.org/wiki/Spiral
rigid solutions exist already in rosetta code https://rosettacode.org/wiki/Spiral_matrix#Python the trick is to oblate the spiral and smooth the steps
NedCharles
Many thanks,
I will try this !
NedCharles
Dear Dan,
Based on our last discussions(Spiral matrix !) , I see that you understand the problem very well. Your beginnings of solution are very good but I would like to be able to apply them to a layers of polygons. Thank you for explaining to me how to number this layer of polygons.
Thank you so much, we are close to the solution
Ned... started on an explanation... then saw the shapefile attachment.
I will work on it sometime today with some ideas
XanderBakker
Esri Esteemed Contributor
Interesting what you can get if you don't create a "rectangular spiral" as in the image the OP provided, but just follow the line of a somewhat oval spiral (since the input area is a rectangle and not a square):
However, this is not what the OP wants...
I do think that the spacing used between the lines of the spiral will influence the resulting order. This might be something to look at.
XanderBakker
Just to add some explanation of what I did. I created two scripts, one to create the spiral and the other one to order the polygons.
The first script to create the spiral looks like this:
def main():
    # formulas:
    #  x = phi cos phi
    #  y = phi sin phi
    import arcpy
    from math import pi, sin, cos
    arcpy.env.overwriteOutput = True
    # settings
    fc_parcels = r'C:\GeoNet\Spiral\Parcels.shp'
    fc = r'C:\GeoNet\Spiral\data.gdb\oval_spiral_v01'
    sr = arcpy.Describe(fc_parcels).spatialReference
    scale_extent = 1.25 # size it to 125%
    pnts_cnt = 1000
    pnts_div = 40.0
    # determine output extent
    ext = arcpy.Describe(fc_parcels).extent
    ext = ScaleExtent(ext, scale_extent)
    # run 1, create the normal spiral
    lst_x, lst_y, lst_xy = [], [],[]
    lst = range(pnts_cnt)
    for i in reversed(lst):
        phi = float(i) / pnts_div * pi
        x = phi * cos(phi)
        y = phi * sin(phi)
        lst_x.append(x)
        lst_y.append(y)
        lst_xy.append((x, y))
    # determine scaling of spiral
    x_factor, y_factor, x_offset, y_offset = DefineScaling(lst_x, lst_y, ext)
    # run 2, translate the spiral
    pnts = []
    for xy in lst_xy:
        x = xy[0] * x_factor + x_offset
        y = xy[1] * y_factor + y_offset
        pnt = arcpy.Point(x, y)
        pnts.append(pnt)
    polyline = arcpy.Polyline(arcpy.Array(pnts), sr)
    arcpy.CopyFeatures_management([polyline], fc)
def ScaleExtent(ext, scale_extent):
    new_width = ext.width * scale_extent
    new_height = ext.height * scale_extent
    x_cc = (ext.XMin + ext.XMax) / 2.0
    y_cc = (ext.YMin + ext.YMax) / 2.0
    return arcpy.Extent(x_cc - new_width / 2.0, y_cc - new_height / 2.0,
                        x_cc + new_width / 2.0, y_cc + new_height / 2.0)
def DefineScaling(lst_x, lst_y, ext_out):
    xmin, xmax = min(lst_x), max(lst_x)
    ymin, ymax = min(lst_y), max(lst_y)
    width_in = xmax - xmin
    height_in = ymax - ymin
    x_factor = ext_out.width / width_in
    y_factor = ext_out.height / height_in
    x_offset = ext_out.XMin - xmin * x_factor
    y_offset = ext_out.YMin - ymin * y_factor
    return x_factor, y_factor, x_offset, y_offset
if __name__ == '__main__':
    main()
And it creates the spiral line.
Just to validate if it crosses all the polygons I manually did a select by location (but you can easily script this too).In case it doesn't select all the parcels, one should play with the values for pnts_cnt and pnts_div which define the number of spins.
In case it does select all the second step is to define the order of the parcels. This is done by first performing an intersect between the spiral line and the parcels. This too I did manually, but you can script this also. The resulting line featureclass will have all the intersecting segments. Next you will have to do a Multipart to Singlepart to ceate a feature for each part.
The order is then defined by the second script that validate the center of the segment on its position on the spiral. The lower this position (0-100%) the lower the assign value for the order.
def main():
    import arcpy
    fc = r'C:\GeoNet\Spiral\data.gdb\spiral_parcel_intersect_mp2sp_v01'
    fld_id = 'FID_Parcels'
    fc_spiral = r'C:\GeoNet\Spiral\data.gdb\oval_spiral_v01'
    fld_out = 'Result'
    # get data into dcts
    dct_fc ={r[0]:[r[1], r[2]] for r in arcpy.da.SearchCursor(fc, ('OID@', 'SHAPE@', fld_id))}
    spiral = arcpy.da.SearchCursor(fc_spiral, ('SHAPE@')).next()[0]
    # create the dictionary with the position
    dct_parcels = {}
    for oid, lst in dct_fc.items():
        polyline = lst[0]
        fid = lst[1]
        pntg = polyline.positionAlongLine(0.5, True)
        pos = spiral.measureOnLine(pntg, True)
        if fid in dct_parcels:
            # there can be multiple intersects
            min_pos = dct_parcels[fid]
            if pos < min_pos:
                dct_parcels[fid] = pos
        else:
    # assign the order based on position
    dct_res = {}
    cnt = 0
    for fid, pos in sorted(dct_parcels.items(), key=lambda x: x[1]):
        cnt += 1
        dct_res[fid] = cnt
    # add output field to the parcels
    if len(arcpy.ListFields(fc_parcels, fld_out)) == 0:
        arcpy.AddField_management(fc_parcels, fld_out, "SHORT")
    # update the parcels
    flds = ('OID@', fld_out)
    with arcpy.da.UpdateCursor(fc_parcels, flds) as curs:
        for row in curs:
            fid = row[0]
            if fid in dct_res:
                row[1] = dct_res[fid]
                curs.updateRow(row)
    main()
The result will look like this:
Since your spiral is more rectangular, the code would have to generate the "spiral" in a different way.
Looks good!  If distance and direction to the parcel centroids are needed, I can provide those pieces to supplement this.
The minimum spiral tightness to ensure complete selection of all the parcels could be an iterative process, but I suspect 'corner-cases' can be found for any implementation.
XanderBakker
This could be a result using the "rectangular spiral":
Results depend highly on the spacing size...
def main():
    import arcpy
    # settings
    fc = r'C:\GeoNet\Spiral\data.gdb\rectangle_spiral_v10'
    spacing = 250.0
    x = ext.XMin
    y = ext.YMax - spacing
    # loop
    finished = False
    pnts = [pnt]
    xmin = x
    xmax = ext.XMax
    ymax = y
    ymin = ext.YMin
    done = []
    while finished == False:
        xmax -= spacing
        while x < xmax:
            xy = "{}#{}".format(x, y)
            if not xy in done:
                done.append(xy)
                pnts.append(arcpy.Point(x, y))
            x += spacing
        ymin += spacing
        while y > ymin:
            if not xy in done:
                done.append(xy)
            y -= spacing
        xmin += spacing
        while x > xmin:
            if not xy in done:
                done.append(xy)
            x -= spacing
        ymax -= spacing
        while y < ymax:
            if not xy in done:
                done.append(xy)
            y += spacing
        if (xmax - xmin) < spacing and (ymax - ymin) < spacing:
            finished = True
    # create the rectangle spiral
    main()
I was playing with that idea in a slightly different fashion.
If you make a polyline of the extent, then select by location those parcels that touch it, you can order the outer 'spiral' beginning at the top left and proceeding clockwise until you reach the parcel just below your start parcel .  You remove those parcels, form a new extent from the remaining parcels and proceed again.  It was getting too slow, so I quit.
I think your ideas are good and I would keep the multipart intersection of the parcels with the spiral and the data can be carried over.
Which lines up well with radiating lines.
I could have sworn that there was a select by location option that accepted 'contains the endpoint of' but I couldn't find it.  Would have made things a lot easier for me.
NedCharles
Dear Xander Bakker
The "rectangular spiral" seems to me the most suitable.
Since I am a beginner, I can not run the script by copying it to the Python window on ArcGIS. I would like, if possible, to have a procedure to be able to execute it correctly. For this, I send you a small group of parcels (168) in a geodatabase. Please help me understand the parts of the script that I have to modify later for other lots of parcels.
Many thanks.
PS: Some print screen could help too.
