Issue with the deep learning tutorial: "Detecting Swimming Pools using Satellite Imagery and Deep Learning"
500
06-26-2026 12:50 PM
SadieMCarlson
Detecting Swimming Pools using Satellite Imagery and Deep Learning | ArcGIS API for Python | Esri De...
There is an issue in this tutorial with the following snippet of code:
ds = analytics.get_datastores(gis=gis)
ds.search()
where the .get_datastores() function returns a Nonetype, so ds.search() is not a valid call. analytics and gis are declared as follows in the tutorial:
from arcgis import GIS, learn
from arcgis.raster import analytics
gis = GIS('home')
What could be the issue here? It is impeding my ability to complete this training. Many thanks!
BobBooth1
Do you have a raster analytics image server in an ArcGIS Enterprise instance?  If not, try skipping that code and the next couple lines, down to the lines:
samplefolder = "pool_chips_test"
samplefolder
Then edit that cell to define a path to a sample folder on your machine, such as:
samplefolder = "C:/MyRasterChips/pool_chips_test"
samplefolder
 You'll need to adapt the pathing later to use this local folder.
