import_data Documentation or Code Bug
1919
01-15-2018 09:20 AM
JoshuaBixby
This question is directed at the ArcGIS API for Python staff participating in GeoNet.
I am trying to determine whether there is a software or code bug with import data - arcgis.gis module — arcgis 1.3.0 documentation.  According to the documentation, import_data works with a Pandas dataframe and can load a Pandas dataframe spatially if address_fields are present.
While helping troubleshoot UnboundLocalError: local variable 'fc_layer_definition' referenced before assignment, I came to find that including "x" and "y" fields in a Pandas dataframe is supported, and that points will be automatically created without adding any additional arguments.  Attempting to generate a spatial dataframe similarly, spf = arcgis.features.SpatialDataFrame.from_df(df), generates an error and says no address fields are present.
So, is import_data supposed to support adding Pandas dataframes with "x" and "y" columns or not?  If yes, where is that documented?
AndrewChapkowski
Can you please add an example CSV that you are trying to use?
Also, can you post your code as well?
JoshuaBixby
I took the screenshot of data from https://community.esri.com/thread/207898-unboundlocalerror-local-variable-fclayerdefinition-referenc... and uploaded it as a CSV after renaming long,lat columns to x,y.
