Get all maps that contain a feature layer - Python API
16721
12
10-07-2020 06:38 AM
TanGnar
Is it possible to find all of the maps that contain any one feature layer in ArcGIS Online using the Python API? For example, if there is a feature layer using frequently across the organization, and I want to find out which maps are using that layer.
I see some documentation about finding relationships between items here. The Map2Service seems to work in one direction - find the services in the map. But is there a way to do this the other direction?
SavageTrimble
""" Performed some updates for newer versions of Python API in an ArcGIS Pro 3.1.x setting which got rid of the PropertyMap Attribute error.
Date: 10-23-2023
def find_maps_with_layer(lyr_to_find, map_item_query='1=1'):
web_map_items = gis.content.search(query=map_item_query, item_type="Web Map", max_items=10000)
print(f"Searching {len(web_map_items)} web maps")
maps_with_layer = []
for item in web_map_items:
found_it = False
wm = WebMap(item)
lyrs = wm.layers
for lyr in lyrs:
if hasattr(lyr, 'url') and lyr.url is not None:
if lyr_to_find in lyr.url:
found_it = True
break
if found_it:
maps_with_layer.append(item)
print(f"Found {len(maps_with_layer)} maps which contain the layer")
return maps_with_layer
# Parameters:
lyr_to_find = 'https://<domainurl>/<webadaptor>/rest/services/<nameoffeatureservice>/FeatureServer'
map_item_query = "Title:*"
# Get a list of web maps with the layer:
maps_with_layer = find_maps_with_layer(lyr_to_find, map_item_query)
# Print the titles of web maps containing the layer:
for item in maps_with_layer:
print(f'Web Map Title: {item.title}')
ChrisPeak
Thanks @SavageTrimble!  I wonder if you have a version of this script with the indentation intact?  It looks like that was automatically removed by the site here.  Thanks!
MBocek
Does anyone know of existing updated versions of the admin scripts? The API version 2.4.2 has deprecated so many functions that most samples do not work.
