FeatureLayerCollection.replicas.create always returns the correct tables but 0 records in the tables
673
6
a month ago
Trippetoe
Hi there. I have a python script that attempts to export a hosted feature service as a file geodatabase using the  python api's featurelayercollection.replicas.create() method. I am running python 3.11.10 and arcgis api 2.3.0
The service details:
- One feature layer (id: 0, geometry type: point) with attachments
- One related table (id: 1) with attachments
- Sync is enabled
- supportsSyncModelNone = true
The problem:
the replicas.create() operation consistently returns a file geodatabase with the correct schema but 0 rows in all tables, regardless of parameters used.
What works:
  • Using the AGOL Item Details page to Export as file geodatabase.
  • A direct query on layer 0 returns the expected 27 records
  • Running createReplica manually via the REST Services Directory HTML form returns the expected number of records
What I've have tried (all returning 0 rows):
  • syncModel=none with no geometry filter
  • syncModel=none with geometry set to the service's full extent
  • Adding layerQueries with where=1=1, useGeometry=false, includeRelated=true, queryOption=useFilter for both layers
  • syncDirection=bidirectional
  • geometryType=esriGeometryPoint
  • async=true and async=false
  • layers as comma-separated string (0,1) and as JSON array ([0,1])
  • using an empty querylayers
  • using a populated queryLayers with filter set to 1=1
Any thoughts on how to get the expected number of records returned?
KenGalliher1
@Trippetoe This is a great question. I'm looking into it now. Can you provide a code snippet that shows how you are setting up the replica? What are the sync options, geometry and layer queries look like?
Trippetoe
Thanks for your response. I'm a bit behind you so i'll answer this response first.  Here's my python code that uses `replicas.create()`. As noted in my question, the code returns an empty file geodatabase...
edit_date_filter = "EditDate >= '"+str(last_successful_run_date)+"'"
feat_srvc = arcgis.features.FeatureLayerCollection(settings.AGOL_FEATURE_SERVICE_URL, agol_security_token)
export_job = feat_srvc.replicas.create(
	replica_name='NameDoesNothing',
	layers=[settings.FS_IDX, settings.CONDITION_IDX],
	layer_queries={
		str(settings.FS_IDX):{
			"queryOption":"useFilter", "where":edit_date_filter},
		str(settings.CONDITION_IDX):{
	geometry_filter=None,
	replica_sr=None,
	transport_type='esriTransportTypeUrl',
	return_attachments=True,
	return_attachments_databy_url=False,
	asynchronous=True,
	attachments_sync_direction='bidirectional',
	sync_model='none',
	data_format="filegdb",
	replica_options=None,
	wait=False,
	out_path=settings.DOWNLOAD_DIR,
	sync_direction=None,
	target_type='client')
Just for good measure, i'm including this 'direct request' against the createReplicas endpoint. the results are the same. a perfectly fine, but empty, file geodatabase.....
url = f"{feat_srvc.url}/createReplica"
data = {
	'f': 'json',
	'replicaName': 'test_direct4',
	'layers': '[0,1]',
	'layerQueries': '{"0": {"where": "1=1", "useGeometry": false, "includeRelated": true, "queryOption": "useFilter"}, "1": {"where": "1=1", "useGeometry": false, "includeRelated": true, "queryOption": "useFilter"}}',
	'geometryType': 'esriGeometryPoint',
	'returnAttachments': 'false',
	'syncModel': 'none',
	'syncDirection': 'bidirectional',
	'dataFormat': 'filegdb',
	'async': 'false',
	'token': agol_security_token._con.token
response = requests.post(url, data=data)
print(response.json())
dl_url = response.json().get('responseUrl')
resp = requests.get(url=dl_url, params={'token': agol_security_token._con.token})
zipped = zipfile.ZipFile(io.BytesIO(resp.content))
KenGalliher1
@Trippetoe I was not able to reproduce the missing rows with a file geodatabase or SQLite geodatabase. Here is the code I used. Let me know if you have any questions.
import time
import tempfile
from arcgis.features.layer import FeatureLayerCollection
from arcgis.gis import GIS
from arcgis import geometry
gis = GIS(profile="your_online_profile")
item = gis.content.get("401876e7f782419dbd29974ce8a4e11b")
flc = FeatureLayerCollection(item.url, gis)
output_gdb_path = tempfile.TemporaryDirectory()
service_url = flc.url
extent = {
    "xmin": -13238397.099502765,
    "ymin": 3923105.9219284547,
    "xmax": -13037402.432768419,
    "ymax": 4065046.3578960407,
geom_filter = geometry.filters.envelope_intersects(extent)
sync_options = {"syncDataOptions": 260}
layer_queries = {
    "0": {"queryOption": "useFilter", "useGeometry": True},
    "2": {"queryOption": "useFilter", "useGeometry": False},
# For file gdb, the sync model must be none
# For mobile gdb, use "perLayer" or "perReplica"
sync_model = "none"
data_format = "filegdb"
replica_options = {
    "replica_name": f"ReplicaTest_{int(time.time())}",
    "layers": [0, 2],
    "layer_queries": layer_queries,
    "geometry_filter": geom_filter,
    "replica_sr": {"wkid": 102642, "latestWkid": 2226},
    "transport_type": "esriTransportTypeUrl",
    "return_attachments": True,
    "attachments_sync_direction": "bidirectional",
    "sync_model": sync_model,
    "data_format": data_format,
    "replica_options": sync_options,
    "out_path": output_gdb_path.name,
    "sync_direction": "bidirectional",
try:
    res = flc.replicas.create(**replica_options)
    print(res)
except Exception as ex:
    print("Create Replica failed:", str(ex))
finally:
    output_gdb_path.cleanup()
Trippetoe
@KenGalliher1 Thanks for the code example. I changed the code as necessary for my hosted feature service and ran it. unfortunately, i got the same results: an other wise perfect file geodatabase with my related tables, attachment tables, etc - but there we no rows in the feature class, the related table, nor either of the attachment tables. The only table with any rows was the GDB_ServiceItems table.
I don't know why really, but a hunch is that the attachments in the related table are causing the problem. Does your hosted feature service have attachments enabled on the related table (index 2 i believe in your example)?
KenGalliher1
@Trippetoe Yes, I enabled and added attachments on the feature layer and the table. Thanks for providing your parameters. I'll test some of those in my code. I'll let you know what happens.
Trippetoe
@KenGalliher1 I noticed that i left a bad parameter in my code example (I've been trying every option to see what might matter and some slop did not get removed).  The right parameter is
In my original post i had that value as 'download', which does not work.
