Does RasterToPolygon not honour environmental settings?
1372
05-03-2021 07:02 AM
TomGeo
I am running in some strange problems in ArcGIS Pro 2.7.2. Within a notebook  I started to define some environmental settings, setting addOutputsToMap to false and overwriteOutput to true, and I specify the outputCoordinateSystem via
arcpy.env.outputCoordinateSystem = arcpy.SpatialReference(25832)
I retrieve an iterator containing the path of a number of tif files and iterate over it.
Within the iteration I utilize RasterToPolygon
arcpy.conversion.RasterToPolygon(tif,out_fc,simplify="NO_SIMPLIFY",raster_field="Value")
Even though I set outputOverwrite = True I am getting ERROR 000528: Output Path/to/File already exists from RasterToPolygon. Does not happen all the time, but from time to time.
The other problem is the coordinate system defined for the notebook. In case I leave the environmental attribute addOutputsToMap at the default value I get the immediate response while running the RasterToPolygon cell. The feature classes created by the tool are missing the spatial reference!
I checked... all tif files are in EPSG 25832, the feature dataset I am writing the feature classes into is defined in EPSG 25832, and the notebook defines the coordinate system to EPSG 25832.
I was also running the RasterToPolygon in an with-statement, utilizing EnvManger... to no avail.
I wonder where RasterToPolygon drops the coordinate system.
In case it's not meant to honour neither environmental settings, nor inherit spatial references from input files then I wonder why there is no parameter, offering the possibility  to define the output coordinate system for the method.
The Python used here is in version 3.7.9 and I did not clone the environment... it's the default.
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
DanPatterson
From...
Raster to Polygon (Conversion)—ArcGIS Pro | Documentation
these are the environment parameters that are supported
Auto Commit, Current Workspace, Default Output Z Value, Extent, Geographic Transformations, M Resolution, M Tolerance, Maintain Spatial Index, Output CONFIG Keyword, Output Coordinate System, Output has M values, Output has Z values, Output M Domain, Output XY Domain, Output Z Domain, Scratch Workspace, Snap Raster, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
... sort of retired...
