Create Attribute Index using Python API
1798
04-10-2023 01:33 PM
mpboyle
Honored Contributor
If I view the properties of a layer or table within a hosted feature layer, I'm able to view the existing indexes as a dictionary object.
Is it possible to create an attribute index on a hosted feature layer using the Python API?  If so, are there any examples available?  I can't find any in the Python API docs.
mpboyle
Honored Contributor
After some testing, this does seem doable using the Python API.  Below is some sample code that others may find useful.
import arcgis
# connect to portal
portal = arcgis.GIS(...your authentication method...)
# set item
item = portal.content.get('...item id...')
# get layers and tables (in my case I was targeting a table)
layers = item.layers
tables = item.tables
# target layer or table
fl = tables['x']  # x is the index of the layer or table
# create attribute index json/dictionary
idx = {'name': '...name of index...',
       'fields': 'Field1, Field2, Field3, etc...',
       'isAscending': True,
       'isUnique': False,  # only set to True if layer or table has unique values
       'description': '...description of index...'}
# add index to layer/table definition --- seems that whether there is 1 or multiple indexes you are adding, the object must be a list
r = fl.manager.add_to_definition({"indexes": [idx]})
# check result
print(r)
mpboyle
Honored Contributor
import arcgis
# connect to portal
# set item
# check result
print(r)
