Copy web map application and update web map
1600
10-12-2023 04:42 AM
Sfortunatamente
I need to copy a web map application created using Web App Builder and update a web map based on which the app was created. As far as I know the second step has to be done with REST API but making a copy of a web app is more crucial for me at the time.
I tried the same approach which I use for web maps:
newWebMapProperties = {'title': title,
'type': 'Web Map',
'tags': tags
'text': json.dumps(existingWebMapJsonData)}
Which properties do I need to put for web apps in order to get a copy which can be opened and edited in Web App Builder?
David_McRitchie
Hey,
For copying Web Apps I would recommend using the Clone_Items() method. The documentation here provides some useful code samples for doing this.
Let me know if you hit any issues with this.
Many thanks,
David
Esri UK -Technical Support Analyst
Sfortunatamente
Hi, thanks for the tip but clone seems to be dedicated for making a copy from one Portal to another one but what I want to do is to copy with the same Portal instance.
