Clone Portal Users Workflow regarding Remove existing users from target portal
1317
01-12-2017 09:45 AM
XuehanJing
for In[6]
for srcuser in sourceusers:    if not srcuser.username in systemusers:        if srcuser.username is not target_admin_username: #don't delete the account used to connect            try:                targetusr = target.users.get(srcuser.username)                if targetusr is not None:                    print('Deleting user: ' + targetusr.fullname)                    targetusr.reassign_to(target_admin_username)                    targetusr.delete()            except:                print('User {} does not exist in Target Portal'.format(srcuser.username))
if I use targetusr.fullname, it always go to the exception, and never delete the user. But if I use targetusr.fullName I can delete the user without problem.
Is this expected?
RohitSingh2
You're right - it should be targetuser.fullName not targetuser.fullname.
We'll fix this in the sample and the developer website. Thanks for pointing it out.
Rohit
RohitSingh2
Rohit
