Batch Geocode Result write to file Scrambled out of order
1414
04-27-2024 12:54 AM
victhomas
Hello All,
I'm trying to do a batch geocode, then write the results to a CSV file with the lat and long column added on.
Everything works fine, but the final written result to the CSV file is mixed up causing different XY values to be added to the wrong address.
I'm following this YT video: https://www.youtube.com/watch?v=ZbOD8mrX3c8
 Please see attached code and screenshots.  Python 3.9.16 shipped with ArcPro 3.2
Any help or idea as to why this is happening?  Thanks in advanced.
Python Terminal results
CSV file output result - does not match what's in the terminal
code:
import pandas as pd
from arcgis.gis import GIS
from arcgis.geocoding import get_geocoders, batch_geocode, geocode, Geocoder
gis = GIS("https://arcgis.com","user","password")
print(gis.properties.user.role)
GeocodeURL = "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
orgGeoCoder = Geocoder(GeocodeURL, gis)
input_file = "C:\\Users\\temp\\coffeeshops.csv"
output_file = "C:\\Users\\temp\\coffeeshops_coded.csv"
address_column_name = "Address"
data = pd.read_csv(input_file, encoding='utf8')
print(data.head(20))
if address_column_name not in data.columns:
    raise ValueError("Missing Address column in input data")
addresses = (data[address_column_name]+", " + data['City'] + ", " + data['State']).tolist()
results = batch_geocode(addresses=addresses, geocoder=orgGeoCoder)
latcoords = []
longcoords = []
for coordinates in results:
    print("Score "+ str(coordinates['score']) + " : " + coordinates['address'] + " " + str(coordinates['location']))
    latitude = coordinates['location']['y']
    longitude = coordinates['location']['x']
    latcoords.append(latitude)
    longcoords.append(longitude)
data['Long']=longcoords
data['Lat']=latcoords
pd.DataFrame(data).to_csv(output_file, encoding='utf8')
print("done")
Learn how to geocode addresses from a CSV file and store those results in ArcGIS Online or on your local client. 📚 Resources ============= https://developers.arcgis.com/python Questions? We'd love to answer them on Esri Community! 💬 Community forums: ...
PrinceOseiBonsu
# A function that extracts items from a list
def address_extractor_roof(api_response_list)
    This function extracts relevant information
    from API response.
    # Create an empty dataframe
    extracted_df = pd.DataFrame()
    # Create an empty list
    latitude, longitude, match, score, addr_type = [],[],[],[],[]
    # Create a FOR loop to extract the data
    for api_response in api_response_list:
        try:
            # Extract the variables
            latitude.append(api_response[0]['attributes']['DisplayY'])
            longitude.append(api_response[0]['attributes']['DisplayX'])
            match.append(api_response[0]['attributes']['Status'])
            score.append(api_response[0]['attributes']['Score'])
            addr_type.append(api_response[0]['attributes']['Addr_type'])
        except IndexError:
            print(api_response)
    # Append columns to form a dataframe
    extracted_df['latitude'] = latitude
    extracted_df['longitude'] = longitude
    extracted_df['match'] = match
    extracted_df['score'] = score
    extracted_df['addr_type'] = addr_type
    # Return the dataframe
    return extracted_df
