Arcpy required for from_featureclass() method?
1780
05-13-2022 01:15 PM
JohnHuillery1
Is arcpy required to use the from_featureclass() method from the ArcGIS for Python API? I'm attempting to use it on spatially enabled dataframes in an environment that does not have arcpy installed and I'm getting invalid input dataset errors.
I am attempting to read from SDE.
davedoesgis
According to this link, it says:
You must have fiona installed if you use the from_featureclass() method to read a feature class from FileGDB with a Python interpreter that does not have access to ArcPy.
jcarlson
MVP Alum
It shouldn't, I use that function quite often on non-arcpy envs. Admittedly, I've only done this with FGDBs.
When I used the ArcGIS Python API against an enterprise geodatabase, I used pandas.read_sql to do it.
- Josh Carlson
Kendall County GIS
DanPatterson
C:\...install_folder...\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\geo\_io\fileops.py
line 470 -
There are checks for arcpy, no arcpy but has pyshp (for shapefiles) and for fiona
So read through the code for fileops and its import tree, but it appears that pyshp and fiona handle imports for spatially enabled dataframes if you don't have arcpy.
... sort of retired...
davedoesgis
