ArcGIS Python API zoom_to_layer() attribute error
2880
08-10-2020 06:28 AM
TracyWhelen
I am working with the ArcGIS API for Python mapping widget within the ArcGIS jupyter notebook environment. I've successfully connected to my organization's enterprise portal, grabbed content, mapped it, and set the zoom level manually (see code below). The problem is when I try to zoom to the added layer, at which point I receive the error:
AttributeError: 'MapView' object has no attribute 'zoom_to_layer'
According to the arcgis.widgets documentation page and all other Esri tutorials I've seen zoom_to_layer() exists and I'm using the correct syntax, of "map.zoom_to_layer(layer)".
The only thing I can think of is that since my installation of the API is what comes with ArcGIS 10.7.1 (API version 1.6.1) whereas all the online API documentation pages are for version 1.8.2. Is zoom_to_layer() functionality that has been implemented between those two versions? Or can anyone else think of reasons why this might be erroring?
gis = GIS("portal_url", username="my_username")
contentItem = gis.content.get('content_string')
contentLayer = contentItem.layers[0]
m = gis.map()
m.add_layer(contentLayer)
m.zoom_to_layer(contentLayer) #this errors
# m.zoom = 14 #this works fine
m
MehdiPira1
Hi Tracy Whelen‌,
I just checked the ArcGIS API for Python V1.6.1 in the following link:
Release v1.6.1 · Esri/arcgis-python-api · GitHub
The file is downloadable, you can download and check it for yourself. The equivalent notebook file for this link (other Esri tutorials) isusing-the-map-widget.
It looks like  zoom_to_layer  is not available for this version.
I hope that helps.
MehdiPira1
Hi Tracy Whelen‌,
I hope that helps.
TracyWhelen
Thanks Mehdi! That was helpful confirmation.
JoshuaBixby
MVP Esteemed Contributor
Tracy, it seems like your question has been answered.  Please mark a reply correct to close out this question.
