API to Get Item Usage
5301
11-05-2018 04:56 AM
CameronMcCormick
Good Morning,
I have been pulling some item usage data from AGOL using the Python API item.usage().
Seems to be working fine for a few of the queries, and not for others.
My python:
from arcgis.gis import GIS,Item
gis = GIS("https://<organiztion>.maps.arcgis.com","<username>","<password>")
item = Item(gis,"<itemid>")
chartdata = item.usage("<daterange>",as_df=True)
print(chartdata)‍‍‍‍‍‍
The chart below shows which ones work for me.
errors
If I run the 6M range, it returns:
Error generating usage report.
None
If I run the 1Y range, it returns:
 File "<filepath>.py", line 12, in <module>
 chartdata = item.usage("1Y",as_df=True)
 File "<windowsuserfolder>\AppData\Local\ESRI\conda\envs\new-environment\lib\site-packages\arcgis\gis\__init__.py", line 6371, in usage
 raise ValueError("Invalid date range.")
ValueError: Invalid date range.
It doesn't matter whether you return the Pandas DataFrame or the python dictionary for the result, same errors get generated.
Am I missing something somewhere?
It would be really nice to get the longer date ranges for my automated reporting I'm working on.
Thanks for any help on this!!
Cameron
JoshuaBixby
MVP Esteemed Contributor
Are you able to run the queries for 6 and 12 months in AGOL's web page interface?  It could be an AGOL issue and what you are seeing is a symptom of that non-Python issue.
CameronMcCormick
Yes both the 6 months and 1 year queries work in AGOL
simoxu
by MVP Alum
It seems the maximum days in one request is restricted to 60 days.
I searched 1 year in AGOL, and the startTime and endTime in the requests sent by the browser to AGOL are:
startTime: 1512283405000
endTime: 1517467405000
startTime: 1517467405000
endTime: 1522655005000
startTime: 1522655005000
endTime: 1527839005000
startTime: 1527839005000
endTime: 1533023005000
startTime: 1533023005000
endTime: 1538207005000
startTime: 1538207005000
endTime: 1543387405000
startTime: 1543387405000
endTime: 1543819405000
Convert these timestamp (in milliseconds) to datetime, you'll find the regularity:
For example:
time.strftime('%Y-%m-%d %H:%M:%S', time.localtime(1512283405))
'2017-12-03 17:13:25'
This is a bug for the API if the document clearly states it can take 6m and 1y as the date range.
simoxu
by MVP Alum
Hi Cameron,
I was led here by your  post in GitHub, and I also commented there.
item.usage() errors · Issue #321 · Esri/arcgis-python-api · GitHub
Hope it makes sense.
Simo
simoxu
by MVP Alum
This specific issue has been address in the new release of 1.5.2.
arcgis-python-api/release-notes.ipynb at master · Esri/arcgis-python-api · GitHub
