CDN Fallback for ArcGIS JSAPI
4723
04-20-2016 10:50 AM
Here's how I solved the problem of needing a fall back for when/if the CDN goes down.
  1. Download the JS from SDK Downloads | ArcGIS for Developers  and follow the setup instructions.
  2. For the sake of this tutorial, I have placed the 3.16 files at /js/3.16/ on my webserver
  3. Place these two lines of code in place of the normal js include
<script src="https://js.arcgis.com/3.16/"></script>
<script> window.dojo || document.write('<script src="/js/3.16/init.js">\x3C/script>');</script>
It check to see if dojo has been loaded, which is essentially seeing if the js library has been loaded. If not, it loads the local version.
Comments
ChrisSmith7
Honored Contributor
Good idea, I have this as a parameter in the app I can change through a db script, but that requires identifying the problem and applying a fix after the fact. This is a more robust way to do this seamlessly. But, I mean the CDN ​never goes down, right? Right?!
RandyBonds_Jr_
Ha ha, yeah never
Version history
Last update:
‎12-12-2021 09:04 AM
Updated by:
