Slider widget in LayerList/ListItemPanel
3476
09-01-2020 10:46 AM
BenRomlein
Using JS API 4.16, I want to use a Slider widget in the ListItemPanel of my Layer List items, but when I attach an event listener to my slider, it fails to render.
Basically, I have:
const mySlider = new Slider({
    min: 0,
    max: 1,
    steps: .05,
    values: [1],
    snapOnClickEnabled: true,
    visibleElements: {labels: true,
                        rangeLabels: true}
  }).on('thumb-drag'index => console.log(index));
const layerList = new LayerList({
    view: view,
    listItemCreatedFunction: event => {
        const item = event.item
        item.panel = {
            content: [
                mySlider
            open: false
and my Slider isn't rendering.
here's a codepen: https://codepen.io/broms/pen/BaKdXaj
If you uncomment the on('thumb-drag') listener at line 14 in the pen, the slider stops rendering.
I assume the code is correct, because if you uncomment the container property at line 5 (in addition to the above) and draw the slider in its own div, everything works as expected.
Is this a bug, or is there a way to get the Slider to work inside a ListItemPanel?
RobertScheitlin__GISP
Ben,
   Your only issue is you are trying to chain an event listener and that is incorrect.
Here is what you need:
    // container: "sliderDiv",
    min: 0,
    max: 1,
    steps: .05,
    values: [1],
                        rangeLabels: true}
  mySlider.on('thumb-drag', index => console.log(index));
Ben,
    min: 0,
    max: 1,
    steps: .05,
    values: [1],
                        rangeLabels: true}
BenRomlein
Thanks for the answer, Robert. It works perfectly now.
I'll add that creating the Slider inside the listItemCreatedFunction made the code a lot more useful:
    view: view,
            min: 0,
            max: 1,
            steps: .05,
            values: [1],
                                rangeLabels: true}
          mySlider.on("thumb-drag"event => **do things**);
Since this way it has access to the item
