How to Connect to Local Map Server
2070
08-27-2019 04:38 AM
JeffKing3
Greetings,
We are using the esri 4.11 javascript library for our mapping solution.  For our development environment, we have been using the default configuration which connects to the remote tile server (https://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer).  Now we need to point to our local in-house server.  How and where is that configured?
Jeff
RobertScheitlin__GISP
Jeff,
  Have you seen this sample?
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=basemap-custom
Basically you would use that sample but replace web tile layer with
  var layer = new TileLayer({
    url: "https://your server url/arcgis/rest/services/your tile service/MapServer"
JeffKing3
Nobody?
Jeff,
JeffKing3
OK, we were using ArcGISDynamicMapServiceLayer and that didn't work.  The one you are suggesting works. I see now it's a version thing.
Thank you for your help.
