esri.config.default.io.proxyURL not set error
4949
02-12-2013 10:21 PM
kawwen_bin
Evening,
Was working on batch geocoding using a web UI when this error message was returned to me by my own arcgis server. Any idea what is causing it? what can be done about it? I understand that one solution to this is to install and use the proxy page. However, due to project requirement, its best i avoid using the proxy page. Is there any other alternative to solving this error?
This error only pops out when the sample address data set exceeds 13 sets. if i use smaller data sets < 14, the error will not appear and everything will function correctly.
JianHuang
In your case, the input is too long to fit into HTTP GET request. So it has to use POST. In this case, it needs a proxy. Please find more information on:
http://forums.arcgis.com/threads/77128-Export-Web-Map-Task-Error-unable-to-connect-to-map-server-onl...
