In firebug, I get this error when I zoom to the visibility scale of the 'props' layer:exception in animation handler for: onEnd...?v=2.8 (line 14)
TypeError: _69.color is Null...Legend.xd.js (line 19)
If I remove the props layer from both the map and legend objects, the error is gone. Here's what I have:dojo.addOnLoad(init);
var mapLayers = [];
var legendLayers = [];
//Function to initialize the map and read data from Configuration file
function init() {
setupFindTask();
//asp.net proxy page for token service
esri.config.defaults.io.proxyUrl = "proxy.ashx";
//change the location of the map slider
esri.config.defaults.map.slider = { left:"13px", top:"76px", width:null, height:"150px" };
//change zoom options to try and get map to display faster
esri.config.defaults.map.zoomRate = 50;
esri.config.defaults.map.zoomDuration = 1000;
dojo.connect(map, "onLoad", mapLoaded);
dojo.connect(grid1, "onRowClick", onRowClickHandler);
//lets grab the details from the config.txt file
dojo.xhrGet({
url: "Config.txt",
handleAs: "json",
preventCache: true,
load: function (responseObject, ioArgs) {
var mapExtent = responseObject.DefaultExtent;
defaultID = responseObject.defaultID;
defaultFacName = responseObject.defaultFacName;
defaultFacCityState = responseObject.defaultFacCityState;
var startExtent = new esri.geometry.Extent(parseFloat(zoomExtent[0]), parseFloat(zoomExtent[1]),
parseFloat(zoomExtent[2]), parseFloat(zoomExtent[3]), new esri.SpatialReference({ wkid: 102100}));
dojo.byId('imgApp').src = responseObject.ApplicationImage;
dojo.byId('lblAppName').innerHTML = responseObject.ApplicationName;
map = new esri.Map("map", { extent: startExtent});
createBasemapGallery();
dojo.connect(map, "onLoad", MapInitFunction);
//map layers can be added here
function MapInitFunction(map) {
var facils = new esri.layers.FeatureLayer("https://mydomain.com/MapServer/0",{
mode:esri.layers.FeatureLayer.MODE_SNAPSHOT,
outFields:["*"]
legendLayers.push({layer:facils,title:"Facilities"});
var bndry = new esri.layers.FeatureLayer("https://mydomain.com/MapServer/3",{
opacity: 0.7,
outFields:["*"]
legendLayers.push({layer:bndry,title:"Boundary"});
var props = new esri.layers.FeatureLayer("https://mydomain.com/MapServer/2",{
outFields:["*"]
legendLayers.push({layer:props,title:"Property Boundaries"});
dojo.connect(map,'onLayersAddResult',function(results){
var legend = new esri.dijit.Legend({
map:map,
layerInfos:legendLayers
},"legendDiv");
//when the map extent is changed, refresh legend layers since layerInfos is used in legend constructor
dojo.connect(map, "onExtentChange", function(){
legend.refresh();
legend.startup();
map.addLayers([bndry,props,facils]);
//add check boxes
dojo.forEach(legendLayers,function(layer){
var layerName = layer.title;
var checkBox = new dijit.form.CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function(evt) {
var clayer = map.getLayer(this.value);
clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
//add the checkbox and label to the toc
dojo.place(checkBox.domNode,dojo.byId("toggle"),"after");
var checkLabel = dojo.create('label',{'for':checkBox.name, innerHTML:layerName},checkBox.domNode,"after");
dojo.place("<br />",checkLabel,"after");
anyone see this problem before?edit: The problem seems to start at v2.7; changing to v2.5 or v2.6 there is no error, and everything works fine.
