Does the class "esri/toolbars/navigation" exist in ArcGis Javascript 4x
7744
01-22-2019 03:04 AM
bobongubza
I am trying to migrate code from ArcGis Javascript 3x to 4x. I have noticed "esri/toolbars/navigation"  is not on ArcGis Javascript 4x.  I want recreate the navigation toolbars on ArcGis Javascript 4x, simliar to the one on this link ArcGIS API for JavaScript Sandbox (from ArcGis Javascript 3x)
My question is where can I locate a class similar to it on ArcGis Javascript 4x.
RobertScheitlin__GISP
Bobo,
   The 4.x API does NOT have a navigation toolbar like the 3.x API does yet. So I created this app that replicates the 3.x navigation toolbar.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Navigation Toolbar - 4.10</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #tools {
      padding: 1em;
      text-align: center;
    .tool {
      padding-top: 3px;
      padding: 4px 2px;
    .tool.disabled,
    .tool.disabled:hover {
      opacity: 0.6;
      pointer-events: none;
    .tool:hover,
    .tool.selected:hover {
      background-color: rgba(0, 0, 0, 0.5);
    .tool.selected {
      background-color: rgba(0, 0, 0, 0.3);
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
  <script src="https://js.arcgis.com/4.10/"></script>
  <script>
    var _prevExtent, _preExtent,
    _currentvExtent, _extentHistory,
    evtViewDragHandler, evtViewKeyDownHandler, draw,
    fullExtent
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/core/watchUtils",
      "dojo/dom-class",
      "dojo/dom",
      "dojo/on",
      "esri/views/2d/draw/Draw",
      "esri/geometry/Extent",
      "esri/Graphic"
    ], function(Map, MapView, watchUtils, domClass, dom, on, Draw, Extent, Graphic) {
      _prevExtent = false;
      _preExtent = null;
      _currentExtent = null;
      _extentHistory = [];
      _extentHistoryIndx = 0;
      _nextExtent = false;
      var map = new Map({
        basemap: "streets"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 4,
        center: [15, 65] // longitude, latitude
      watchUtils.whenTrue(view, "ready", function(){
        fullExtent = view.extent.clone();
        draw = new Draw({
          view: view
        initToolbar();
        watchUtils.whenOnce(view, "extent", function(){
          watchUtils.when(view, 'stationary', function(evt){
            if(evt){
              extentChangeHandler(view.extent);
      function extentChangeHandler(evt) {
        if(_prevExtent || _nextExtent){
          _currentExtent = evt;
        }else{
          _preExtent = _currentExtent;
          _extentHistory.push({
            preExtent: _preExtent,
            currentExtent: _currentExtent
          _extentHistoryIndx = _extentHistory.length - 1;
        _prevExtent = _nextExtent = false;
        extentHistoryChange();
      function extentHistoryChange() {
        if(_extentHistory.length === 0 || _extentHistoryIndx === 0 ){
          domClass.add(dom.byId("zoomprev"), "disabled");
        } else {
          domClass.remove(dom.byId("zoomprev"), "disabled");
        if(_extentHistory.length === 0 || _extentHistoryIndx === _extentHistory.length - 1){
          domClass.add(dom.byId("zoomnext"), "disabled");
        } else {
          domClass.remove(dom.byId("zoomnext"), "disabled");
      function enableViewPanning() {
        if(evtViewDragHandler){
          evtViewDragHandler.remove();
          evtViewDragHandler = null;
        if(evtViewKeyDownHandler){
          evtViewKeyDownHandler.remove();
          evtViewKeyDownHandler = null;
      function disableViewPanning() {
        evtViewDragHandler = view.on("drag", function(event) {
          // prevents panning with the mouse drag event
          event.stopPropagation();
        evtViewKeyDownHandler = view.on("key-down", function(event) {
          // prevents panning with the arrow keys
          var keyPressed = event.key;
          if (keyPressed.slice(0, 5) === "Arrow") {
      function displayCrosshairCursor() {
        this.view && this.view.container && this.view.container.style && "crosshair" !== this.view.container.style.cursor && (this.view.container.style.cursor = "crosshair")
      function displayPointerCursor() {
        this.view && this.view.container && this.view.container.style && "pointer" !== this.view.container.style.cursor && (this.view.container.style.cursor = "pointer")
      function displayDefaultCursor() {
        this.view && this.view.container && this.view.container.style && "default" !== this.view.container.style.cursor && (this.view.container.style.cursor = "default")
      function removeCurrentSelTool() {
        view.popup.close();
        domClass.remove(dom.byId("panmap"), "selected");
        domClass.remove(dom.byId("zoomin"), "selected");
        domClass.remove(dom.byId("zoomout"), "selected");
      function drawRect(event){
        var vertices = event.vertices;
        //remove existing graphic
        view.graphics.removeAll();
        if(vertices.length < 2){
          return;
        // create a new extent
        var extent = getExtentfromVertices(vertices);
        var graphic = new Graphic({
          geometry: extent,
          symbol: {
            type: "simple-fill", // autocasts as SimpleFillSymbol
            color: [0, 0, 0, 0.3],
            style: "solid",
            outline: { // autocasts as SimpleLineSymbol
              color: [255, 0, 0],
              width: 1
        view.graphics.add(graphic);
      function zoomIn(evt){
        draw.reset();
        var action = draw.create("rectangle");
        view.focus();
        action.on("vertex-add", drawRect);
        action.on("draw-complete", zoomIn);
        action.on("cursor-update", drawRect);
        if(evt.vertices.length === 1){
          view.goTo({scale: (view.scale * .5)});
          return;
        var extent = getExtentfromVertices(evt.vertices);
        if (extent.width !== 0 || extent.height !== 0){
          view.goTo(extent);
      function zoomOut(evt){
        var vertices = evt.vertices;
        draw.reset();
        view.focus();
        action.on("draw-complete", zoomOut);
          view.goTo({scale: (view.scale * 2)});
          return;
        var sx = vertices[0][0], sy = vertices[0][1];
        var ex = vertices[1][0], ey = vertices[1][1];
        var rect = {
          x: Math.min(sx, ex),
          y: Math.max(sy, ey),
          width: Math.abs(sx - ex),
          height: Math.abs(sy - ey),
          spatialReference: view.spatialReference
        if (rect.width !== 0 || rect.height !== 0){
          var scrPnt1 = view.toScreen(rect);
          var scrPnt2 = view.toScreen({x: rect.x + rect.width, y: rect.y, spatialReference: rect.spatialReference});
          var mWidth = view.extent.width;
          var delta = (mWidth * view.width / Math.abs(scrPnt2.x - scrPnt1.x) - mWidth) / 2;
          var vExtent = view.extent;
          view.goTo(new Extent({
            xmin: vExtent.xmin - delta,
            ymin: vExtent.ymin - delta,
            xmax: vExtent.xmax + delta,
            ymax: vExtent.ymax + delta,
            spatialReference: vExtent.spatialReference
      function getExtentfromVertices(vertices){
        var rect = {
          return new Extent({
            xmin: parseFloat(rect.x),
            ymin: parseFloat(rect.y) - parseFloat(rect.height),
            xmax: parseFloat(rect.x) + parseFloat(rect.width),
            ymax: parseFloat(rect.y),
        }else{
          return null;
      function initToolbar() {
        on(dom.byId("zoomfull"), "click", function() {
          view.goTo( fullExtent);
        on(dom.byId("zoomnext"), "click", function() {
          _nextExtent = true;
          _extentHistoryIndx++;
          view.goTo(_extentHistory[_extentHistoryIndx].currentExtent);
        on(dom.byId("zoomprev"), "click", function() {
          if(_extentHistory[_extentHistoryIndx].preExtent){
            _prevExtent = true;
            view.goTo(_extentHistory[_extentHistoryIndx].preExtent);
            _extentHistoryIndx--;
        on(dom.byId("zoomin"), "click", function() {
          removeCurrentSelTool();
          disableViewPanning();
          displayCrosshairCursor();
          view.focus();
          domClass.add(dom.byId("zoomin"), "selected");
        on(dom.byId("zoomout"), "click", function() {
          view.focus();
          domClass.add(dom.byId("zoomout"), "selected");
        on(dom.byId("panmap"), "click", function() {
          enableViewPanning();
          displayDefaultCursor();
          draw.reset();
          domClass.add(dom.byId("panmap"), "selected");
      view.ui.add("tools", "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="tools" class="esri-widget">
    <img src="images/esriZoomIn.png" alt="Zoom In" title="Zoom In" class="tool" id="zoomin" />
    <img src="images/esriZoomOut.png" alt="Zoom Out" title="Zoom Out" class="tool" id="zoomout" />
    <img src="images/esriPan.png" alt="Pan Map" title="Pan Map" class="tool selected" id="panmap" />
    <img src="images/esriZoomFullExtent.png" alt="Full Extent" title="Full Extent" class="tool" id="zoomfull" />
    <img src="images/backward.png" alt="Back Extent" title="Back Extent" class="tool" id="zoomprev" />
    <img src="images/forward.png" alt="Forward Extent" title="Forward Extent" class="tool" id="zoomnext" />
  </div>
</body>
</html>
You have been neglecting to mark any of your question as answered here on GeoNet. This will lead to less responses in the future. Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Bobo,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #tools {
      padding: 1em;
      text-align: center;
    .tool {
      padding-top: 3px;
      padding: 4px 2px;
    .tool.disabled,
      opacity: 0.6;
    .tool:hover,
    .tool.selected {
  </style>
  <script>
    fullExtent
    require([
      "esri/Map",
      "dojo/dom-class",
      "dojo/dom",
      "dojo/on",
      "esri/Graphic"
      _preExtent = null;
      var map = new Map({
        basemap: "streets"
        map: map,
        zoom: 4,
        draw = new Draw({
          view: view
        initToolbar();
            if(evt){
        }else{
        } else {
        } else {
        view.popup.close();
          return;
          geometry: extent,
          symbol: {
            style: "solid",
              color: [255, 0, 0],
              width: 1
        draw.reset();
        view.focus();
          return;
          view.goTo(extent);
        draw.reset();
        view.focus();
          return;
        var rect = {
        var rect = {
          return new Extent({
        }else{
          return null;
          _nextExtent = true;
            _prevExtent = true;
          view.focus();
          view.focus();
          draw.reset();
  </script>
</head>
<body>
  </div>
</body>
</html>
bobongubza
Thanks for helping me out once again. I really appreciate it.
