Cannot make dynamic TabContainer in popupTemplate work API 4.19
840
04-15-2021 03:13 AM
ChristopheS
Hi all,
I cannot figure out how to make dynamic TabContainer in popupTemplate work API 4.19
Here is the simplified code :
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title>Test Tabs in Popup JS API 4</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.19/esri/themes/light/main.css" />
	<style>
		html,
		body,
		#viewDiv {
			padding: 0;
			margin: 0;
			height: 100%;
			width: 100%;
	</style>
   	<script src="https://js.arcgis.com/4.19/"></script>
    <script>
	var map;
	require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/layers/TileLayer", "esri/geometry/Extent", "esri/geometry/Point", "esri/PopupTemplate", "esri/popup/content/CustomContent", "dojo/parser", "dojo/dom-construct", "dijit/registry", "dijit/layout/ContentPane", "dijit/layout/TabContainer"	],
	function(Map, MapView, FeatureLayer, TileLayer, Extent, Point, PopupTemplate, CustomContent,
	dojo_parser, dojo_dom_construct, dijit_registry, dijit_ContentPane, dijit_TabContainer)
		var aLayerCapt = new FeatureLayer( "https://xxxCapt/FeatureServer/0" );
		addPopupTemplateData( aLayerCapt, "Captag");
		var aLayerCanal = new FeatureLayer( "https://xxxCanal/FeatureServer/0" );
		addPopupTemplateData( aLayerCanal "Canalisation");
		var aBasemapLayer = new TileLayer( "https://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" );
		var bounds  = new Extent({ "xmin":1.763102,"ymin":42.595217,"xmax":1.868647,"ymax":42.763970, spatialReference: { wkid: 4326 } });
		const map = new Map(
		const viewObject = new MapView(
			container: "viewDiv",
			map: map,
			extent: bounds,
		map.addMany([aBasemapLayer, aLayerCap, aLayerCanal]);
		function addPopupTemplateData( aLayer, title )
			console.log("addPopupTemplateData = " + title);
			const contentWidget = new CustomContent(
				outFields: ["*"],
				creator: getTextContent
			const template = new PopupTemplate(//Set containing of infoWindow
				content: [contentWidget],
				title: title
			aLayer.popupTemplate = template;
		function getTextContent (  graphic )
			var html = "This feature is : " + graphic.graphic.attributes["IDT"];
			var tc = new dijit_TabContainer
					style: "height: 100%; width: 100%;",
					containerNode : "viewDiv"
				}, dojo_dom_construct.create("div" )
			var cp1 = new dijit_ContentPane({
				title: 'Details 1',
				content: "Content pane 1"
			var cp2 = new dijit_ContentPane({
				title: 'Details 2',
				content: "Content pane 2"
			tc.addChild(cp1);
			tc.addChild(cp2);
			//dojo_parser.parse();
			tc.startup();
			return tc.domNode;
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
 The result of a click on a feature gives the two tabs contents being displayed in line one  above the other, but with no tabs effects at all. If there are more than one feature, the subsequent features are empty.
This used to work fine in 3.x, and we are currently upgrading to API 4.x,
Regards
