arcgis/cli styles tool issue
2288
05-26-2021 01:06 PM
by Anonymous User
Not applicable
I installed @arcgis/cli using 'npm install -g @arcgis/cli' on my Windows machine. When I create a new directory, cd into it, and then try to run the 'styles create' command, this is the error it produces:
C:\Users\cfb215.STATE\Desktop\testStyles>arcgis styles create newStyle
copying base
copying examples
copying preview file
arcgis styles create [theme]
Create a custom theme
Positionals:
theme the name of the theme to create [string] [default: "my-custom-theme"]
Options:
--version Show version number [boolean]
-e, --with-examples when specified, the created theme will include examples
from the API [boolean]
-b, --with-base when specified, the created theme will include base files
for local overrides (advanced) [boolean]
-f, --force overwrites a theme if it already exists [boolean]
-h, --help Show help [boolean]
NestedError: Cannot copy `preview/`: the file doesn't exist
at C:\Users\cfb215.STATE\AppData\Roaming\npm\node_modules\@arcgis\cli\node_modules\cpy\index.js:96:10
at runMicrotasks (<anonymous>)
at processTicksAndRejections (internal/process/task_queues.js:93:5) {
nested: undefined,
Is this a know or common issue? It looks like the file does exist but for some reason isn't able to be copied to the new
Tags (3)
by Anonymous User
Not applicable
Okay, I just tried without the capital 'S' in the name, all lowercase and it appears to have worked. If that is documented, I missed it.
by Anonymous User
Not applicable
ReneRubalcava
Esri Frequent Contributor
This is odd. Windows I assume? The command definition isn't camelcase https://github.com/Esri/arcgis-js-cli/blob/master/src/commands/styles.ts#L4 So i'm not sure why that would happen. I don't use Windows often, but will still take a look. Thanks!
by Anonymous User
Not applicable
Yes, this is on a Windows 10 box. Thanks for checking in.
Using lowercase is not a big deal, but was confusing! I was able to successfully output a main.css file. However the styles tool still does not like to preview the theme (cannot GET error in Chrome), and if I eject the theme is remains in the directory but can not be ejected again. Let me know if you want any more detail or error messages. Thanks
