Zoom to a single point!
1477
07-08-2010 06:18 AM
PaulLang
Get a query to zoom to a single point?
I have multiple points and polygon working, but not single point.
RobertScheitlin__GISP
Paul,
  The way ESRI handles it in their viewer is to set the maps scale to some predetermined value and center the maps extent on the MapPoint.
ReneRubalcava
Esri Frequent Contributor
Center and scale works well, but I use this function after determining it's a single point.
You could also have it check geometry type in the function to be safe if you want.
public static function getMapPointExtent(geometry:Geometry):Extent {
 if (geometry) {
  var mapPoint:MapPoint = geometry as MapPoint;
  return new Extent(mapPoint.x, mapPoint.y, mapPoint.x, mapPoint.y, mapPoint.spatialReference);
 else
  return new Extent();
PaulLang
This is what I went with, thanks to you both for your help!
private function addressQuery():void
         graphicsLayerAddress.clear();
         queryTaskAdd.execute(queryAdd, new AsyncResponder( onResult, onFault));
            function onResult(featureSet:FeatureSet, token:Object = null):void
             if (featureSet.features.length == 0)
                 Alert.show("Please try again.");
                else
              for each (var GraphicAddress:Graphic in featureSet.features)
               GraphicAddress.toolTip = "High School:  " + GraphicAddress.attributes.DISTHIGH + "\n" + "Middle School:  "
               + GraphicAddress.attributes.DISTMIDDLE + "\n" + "Elementary School:  " + GraphicAddress.attributes.DISTELEMEN + "\n" +
               "Police District:  " + GraphicAddress.attributes.PoliceDistricts + "\n" +
               "Fire District:  " + GraphicAddress.attributes.FireDistrict  + "\n" +
               "EMS Rescue:  " + GraphicAddress.attributes.EMSRESCUE + "\n" +
               "EMS Gems:  " + GraphicAddress.attributes.EMSGEMS;
              var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(featureSet.features);
              if (featureSet.features.length == 1)
               var gra:Graphic = GraphicAddress;
      var pt:MapPoint = null;
      pt = gra.geometry as MapPoint;
      MainMap.scale = 1200;
      MainMap.centerAt(pt);
              else
                        MainMap.extent = graphicsExtent;
     dpFlat.push(dataGridAddress.dataProvider.toString());
            function onFault(info:Object, token:Object = null):void
                Alert.show(info.toString());
