XY Coordinates
1368
6
10-12-2010 01:01 PM
NadeemShaukat
In ESRI's online seminar demonstration on 9/23/10, XY coordinates were shown below the scalebar, but in flexViewer 2.1 does not show them. Should it be by default or some change must be made in the config file?
RobertScheitlin__GISP
Nadeem,
You have to add the coodinateWidget like this to the config
 <widget left="3" bottom="3" config="widgets/Coordinate/CoordinateWidget.xml" url="widgets/Coordinate/CoordinateWidget.swf"/>
PaulLang
Widget loads with an icon.
I would like it to preload with no icon.
This gets the preload, but how do you remove the icon
preload="open" icon=""
Paul,
   The coordinateWidget is not suppose to go in a widget container and that is likely your issue. Look at the config-all.xml for an example of where to put this widget in your config file.
PaulLang
Thanks for your response and all that you do for our profession.
This statement already is in config-all.xml, but the coordinates do not display.  If I add to container coordinates will display.
Got it!
NadeemShaukat
Robert,
Thanks much for your help. I did exactly what you suggested and the coordinates show up under the scale bar without an icon in the Widgets Bar.
PaulLang
It worked for me also; I did edit my last post to say Got it!
